lost 2.5 quarts of oil in a weekend
ok i got a 00 civic with a gsr swap. this weekend i was driving to NY from Boston total miles back and forth about about 550 miles i checked my oil this morning and i was missing 2.5 quarts. another thing is my car is smoking so is it the rings going bad? headgasket? or other problems?
Re: lost 2.5 quarts of oil in a weekend (94allmotor)
if ur burning oil ur rings might be bad, and what color is the smoke in back of your car, also do u have any leak spots
a compression test and a wet compression test could help you out alot. or a vacuum test. it could be a couple of thing valve seal, piston rings, head gasket. thats why its good to do one of the test before you start replacing parts without knowing what was it.
Re: (civiceg94)
I lost 2.5 quarts since my last oil change, which was in late July, and there is no smoke coming out of the exhaust. there arent any leaks where ever i park.
their some oil stains but tom. on my day off im gonna clean the head and part of the block to check for leaks. im pretty sure their are leaks but that wont make me lose 2.5 quarts over the weekend the leaks are very minimal
ILLA_00LS
07-22-2003 12:06 PM
