GSR turbo the T3 burner?
Old May 30, 2006 | 11:01 AM
HondAcura's Avatar
Default GSR turbo the T3 burner?
I was just in a discussion about how a t3 47 trim is too small for a GSR. I heard it said that the high revving vtec motor will actually burn the t3 fairly quickly. How accurate is this guys? thanks
Old May 30, 2006 | 03:52 PM
TheShodan's Avatar
Moderator
Default Re: GSR turbo the T3 burner? (HondAcura)
This all depends on what you're trying to accomplish here. Just saying its bad is a matter of perspective. Are you trying to get a certain Torque at a certain rpm? Or are you trying to be the standard norm of about 250-300whp? If the latter is the case, then yes, it is rather made for building torque at a lower rpm band, not for all around use where it can effectively use the the 2nd set of lobes and good flowing VTEC head..
Old May 30, 2006 | 05:53 PM
Bseriescivic5's Avatar
ok, but how is a vtec motor going to "blow" the turbo that makes no sense........?
Old May 30, 2006 | 06:32 PM
TheShodan's Avatar
Moderator
Default Re: (Bseriescivic5)
I think he means "burn out" as in run out of effective CFM, but hell, you kids and all your slang
KdF
May 31, 2009 06:38 PM
civicman69x
Feb 27, 2008 11:00 PM
GsRHatchy1320
Aug 28, 2004 09:55 AM
nofatchicks
Mar 18, 2004 04:32 PM
batboyvaj
Apr 5, 2002 04:42 AM
