b16a timing off
Old May 29, 2006 | 11:57 AM
teamredline9k's Avatar
Default b16a timing off
i have a 91 crx si and i swapped a b16 in, and its been working for a good 2-3 months and i was just crusin along and it sounded like it was out of gas and started backfiring and just died. so when i took it to my house i was gettin fuel and spark so the only other reason it wont start is the timing right? and how do u set it if the timing belt jumped or skipped at the crank?
Old May 29, 2006 | 12:46 PM
EG civic's Avatar
Default Re: b16a timing off (teamredline9k)
use a timing light would probably be the fastest way to check
Old May 29, 2006 | 12:54 PM
Default Re: b16a timing off (EG civic)
i cant use a timing light cuz it wont start
Old May 29, 2006 | 01:14 PM
cjames235's Avatar
rotate the crank to TDC and make sure both the cam gears face "up"...... the gears have up on them if they are out of alignment then you will know thats the problem
Old May 29, 2006 | 01:15 PM
cjames235's Avatar
Default Re: b16a timing off (cjames235)
and if you rotate the crank to TDC and the cam gears look like the "up" is facing down then you are at TDC for number 4 so rotate it around again till the gears are at up or the general area of up
Old May 29, 2006 | 01:20 PM
k i have crank on tdc and both cams on up and both little lines on the cams line up so i have that right, right? so when i try to start it up the spark SHOULD be right on right? then i need to adjust the spark advance right?
Old May 29, 2006 | 01:52 PM
cjames235's Avatar
as long as your crank is on the TDC mark and your cam gears are both facing "up" vertical....... then your timing is set right
if its correct i would look into the distributor it could be a coil, cap & rotor, etc
Old May 29, 2006 | 03:01 PM
Jago's Avatar
you can use a timing light to check even if it won't start. connect to the bat then to the #1 plug wire point at the mark pull the trigger and have someone crank it.
Have you had the disstributer cap off this sounds almost exactly like a problem I came across at school and at work. where the rotor comes off the dis shaft because the screw falls out. preaty common on older 91 civics. if the rotor came loose in can still spark but not at the right time.
Old May 29, 2006 | 06:12 PM
Default Re: b16a timing off (Jago)
ill check that would the rotor be hard or really loose?
wagonvanny
Apr 14, 2015 06:12 PM
EdwinCheng
May 7, 2014 01:28 PM
SiRCiviC94
Sep 6, 2013 09:45 PM
Project_CD5
Jul 25, 2007 03:20 AM
00Red_SiR
Feb 10, 2007 06:49 AM
