B16 complete rebuild, now MISFIRE, help!
After completing a full rebuild on my buddies 99 Si, i now have an issue.
First off, its a complete stock rebuild with .25MM over p30 pistons, new Honda rings, ACL bearing kit and all machine work done at reputable shop. The head had a full valve job with installation of Ferrea valves and complete head pressure test. I then completed a valve adjustment after to clearify that also.
After starting it up it sounds great, but has a misfire. I pull #3 wire and no change, #3 is dead. I swap injectors, same thing. I swap plug and wire, same thing. I check all connectors/vaccum, same thing. I ran compression and pulled 160 or so right accross the board (motor literally has 5 minutes of running time) so my compression is there. Ive checked the voltage at the injector connector and getting full signal. So as far as i can tell, im getting fuel, ignition and compression, so it should be happening. Every other cylinder runs great and it actually runs good even with the dead cylinder, i cant wait to see how it runs after being on all 4.
I just need to get this fixed ASAP as i cannot run it much longer with a dead cylinder, ill mess that baby up and wash out the walls. I need this fixed.
Ok, throw some ideas my way, any questions or watever shoot away...
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoej8 »</TD></TR><TR><TD CLASS="quote">are you getting spark at all on #3 wire?</TD></TR></TABLE>
Yes i am. At first i didnt think so cuz i could pull that wire off the plug and not get any arching from it, but i put a screwdriver in there and arched it to a ground and it sparked consistenly there, i also have full spark at the dizzy side of the wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">check your timing</TD></TR></TABLE>
Would timing being off a little bit cause the 3 other cylinders to run perfect and just have a completely dead cylinder in #3? Im thinking i have more of a specific cylinder problem here, lying in either fuel or spark, i hope.
Dan
Dan
I will do that, thanks, but wouldnt i get a dead miss in number 4 then too?
Im currently picking up a OB2 scanner from work and getting a node light to test the injector pulse. Ill post up an update after that.
Dan
Dan
I just finished a noid test for the injector, looks good. I put a spare spark plug in the wire and started the car then grounded the plug, i have a strong spark there. So, i have fuel and i have spark. I will be completing a leakdown test tonight, both a standard and then i will drop a screwdriver in the cylinder, locate TDC for sure, and then again, im hoping im out of time, even tho only one cylinder has the problem.
DAan
DAan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o5mar1 »</TD></TR><TR><TD CLASS="quote">change your spark plug wire, it may be able to spark when you grounded the plug with the screwdriver but under pressure it might not arc.</TD></TR></TABLE>
I swapped that #3 wire to the #2 cylinder and it fired perfect, so ive eliminated that possibility, thanks for chiming in tho
Leakdown test shows less than 5% leakdown in every cylinder, both by cranking it up and starting it at TDC then charging it up.
I still get injector pulse via the noid test and i get spark via testing it on another spark plug attached to wire and grounding it out. I get full compression at TDC of #3 and every other cylinder so i know mechanical timing is right.
Im at a total loss, help.
Dan
Dan
I would check the injector spray pattern. yea u checked the pulsing and stuff but that doesnt check the spray. its has to be vaporized in order for gasoline to ignite i would check that then. and what the hell u have a new motor give it a tune up with new wires, plug... you know the deal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 »</TD></TR><TR><TD CLASS="quote">I would check the injector spray pattern. yea u checked the pulsing and stuff but that doesnt check the spray. its has to be vaporized in order for gasoline to ignite i would check that then. and what the hell u have a new motor give it a tune up with new wires, plug... you know the deal.</TD></TR></TABLE>
So your saying the spray pattern is dictated by the input signal, or the injector itself? Because i did swap out injectors with cyl#4 and the missifire stayed put.
It also has basically new wires, cap, rotor and brand new plugs. But i also swapped that out with another cars components and no change.
Enlighten me a little more on the spray pattern if u would please...thanks for the repsonse.
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoej8 »</TD></TR><TR><TD CLASS="quote">Congrats, on the fix.
so what was the culprit and how did you fix it?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1645129
