B16 complete rebuild, now MISFIRE, help!
Old May 28, 2006 | 10:06 PM
ChillOutWayne's Avatar
Default B16 complete rebuild, now MISFIRE, help!
After completing a full rebuild on my buddies 99 Si, i now have an issue.
First off, its a complete stock rebuild with .25MM over p30 pistons, new Honda rings, ACL bearing kit and all machine work done at reputable shop. The head had a full valve job with installation of Ferrea valves and complete head pressure test. I then completed a valve adjustment after to clearify that also.
After starting it up it sounds great, but has a misfire. I pull #3 wire and no change, #3 is dead. I swap injectors, same thing. I swap plug and wire, same thing. I check all connectors/vaccum, same thing. I ran compression and pulled 160 or so right accross the board (motor literally has 5 minutes of running time) so my compression is there. Ive checked the voltage at the injector connector and getting full signal. So as far as i can tell, im getting fuel, ignition and compression, so it should be happening. Every other cylinder runs great and it actually runs good even with the dead cylinder, i cant wait to see how it runs after being on all 4.
I just need to get this fixed ASAP as i cannot run it much longer with a dead cylinder, ill mess that baby up and wash out the walls. I need this fixed.
Ok, throw some ideas my way, any questions or watever shoot away...
Dan
Old May 28, 2006 | 11:00 PM
Smoke_em's Avatar
From: Inland empire, E.L.A, Douglasville GA, ca, u.s
Default Re: B16 complete rebuild, now MISFIRE, help! (ChillOutWayne)
maybe in the wiring of the that injector connector? doesnt the ECU ground the Injector side . doesnt supply voltage?
Old May 29, 2006 | 08:54 AM
Default Re: B16 complete rebuild, now MISFIRE, help! (Smoke_em)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoke_em &raquo;</TD></TR><TR><TD CLASS="quote">maybe in the wiring of the that injector connector? doesnt the ECU ground the Injector side . doesnt supply voltage?</TD></TR></TABLE>
Thanks for responding, however i am getting voltage at the injector, and it does go up with RPM, we tested that first thing.
Dan
Old May 29, 2006 | 11:33 AM
qfast817's Avatar
check the cap, could be one of the points
Old May 29, 2006 | 01:05 PM
Default Re: B16 complete rebuild, now MISFIRE, help! (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">check the cap, could be one of the points</TD></TR></TABLE>
Cap is in good condition.
I just finished a noid test for the injector, looks good. I put a spare spark plug in the wire and started the car then grounded the plug, i have a strong spark there. So, i have fuel and i have spark. I will be completing a leakdown test tonight, both a standard and then i will drop a screwdriver in the cylinder, locate TDC for sure, and then again, im hoping im out of time, even tho only one cylinder has the problem.
DAan
Old May 30, 2006 | 05:46 AM
Leakdown test shows less than 5% leakdown in every cylinder, both by cranking it up and starting it at TDC then charging it up.
I still get injector pulse via the noid test and i get spark via testing it on another spark plug attached to wire and grounding it out. I get full compression at TDC of #3 and every other cylinder so i know mechanical timing is right.
Old May 30, 2006 | 07:59 AM
Throw some ideas out there...
Old May 30, 2006 | 01:07 PM
BUMP
Old May 31, 2006 | 07:39 AM
Fixed
https://honda-tech.com/zerothread?id=1645129
civilsantana
Aug 8, 2016 04:05 AM
PphamEK
11
Apr 17, 2009 09:13 AM
aasarsak
Apr 3, 2009 06:29 AM
EkFG
17
Jul 9, 2008 09:47 PM
ChillOutWayne
16
May 31, 2006 04:30 PM
