super charger
Old May 28, 2006 | 07:17 PM
BlueLude 94's Avatar
Default super charger
today me and my friend were taliing about super charging my lude. I ad to go boost but he made some good points about why i should go with a super charger. I always have looked at the things like what i would need to go boost and all that other **** but nothign for a a super charger. What do you guys think about this and if i was to go with a super charger instead what would you gus recomend i do inorder for it to run safe and still be a daily driver.
Old May 28, 2006 | 07:30 PM
InvaderTrax's Avatar
If you have an H22, then you can get the Jackson Racing SC. You'll have to do a little work to get it to fit. It's meant for a 97+. If you're H23, you should get a custom Vortec setup. It'll be expensive though. As for being a daily driver, the JRSC has a little **** that lets you vary the boost
Old May 28, 2006 | 07:38 PM
98vtec's Avatar
moderator emeritus
Default Re: (InvaderTrax)
how can you vary the boost on something that runs off belts?
Old May 28, 2006 | 07:40 PM
Dunno, but last I knew, it had a ****. Maybe it's some kind of electronic controller that only lets the boost build up to a certain PSI (then releases the excess like a BOV)
Old May 28, 2006 | 07:43 PM
98vtec's Avatar
moderator emeritus
i believe that is the vtec controller they have. Not boost.
but i really dont know, boost isnt my thing.
Old May 28, 2006 | 07:53 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">the JRSC has a little **** that lets you vary the boost</TD></TR></TABLE>
No it doesn't.
Old May 28, 2006 | 07:57 PM
championshipwhite93si's Avatar
Default Re: (sharkcohen)
god i wish vortech did something for us h23 guys
Old May 29, 2006 | 08:07 AM
Default Re: (championshipwhite93si)
yeah i have a h22. But would it also help to get new cams, rods, pistons and sleeves as if i was gonna go with a turbo or would all that not matter.
Old May 29, 2006 | 08:36 AM
shutta's Avatar
the only thing that can vary the boost on the supercharger is a different pulley
Old May 30, 2006 | 05:20 AM
ludespeed501's Avatar
Default Re: (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">the only thing that can vary the boost on the supercharger is a different pulley</TD></TR></TABLE>
That is correct.
I believe the JRSC comes with a 6lb. pulley and a 9lb. pulley. Too bad its not intercooled.
Old May 30, 2006 | 11:16 AM
darkspector's Avatar
IIRC it only comes with a 6lb pulley and a 9 lbs is available but at 9lbs it's reaching its maximum efficiency
Old May 30, 2006 | 11:30 AM
Default Re: (darkspector)
NOw if i got the JRSC how much would you think im putting down with headers, exhasut, and intake?
Old May 30, 2006 | 11:43 AM
petern101's Avatar
Default Re: (BlueLude 94)
it matters on a bunch of different variables.
you can kinda of get an idea but why bother. you should just dyno it and tune.
if you are looking for a specific hp you want you would need to give that to the experts to see if you will even hit that
DntFk_jdm
Nov 2, 2015 03:19 PM
iNERtIA
Apr 16, 2006 05:31 PM
stockgreencivic
Apr 16, 2004 02:51 PM
HotRodTeg
Oct 4, 2003 11:19 PM
Aquafina
Jun 25, 2003 10:30 AM
