reducing boost on JRSC
Old Apr 15, 2006 | 09:52 PM
iNERtIA's Avatar
Default reducing boost on JRSC
is there a way to decrease boost level without changing the pulleys?
Old Apr 16, 2006 | 06:56 AM
Semnos's Avatar
Default Re: reducing boost on JRSC (iNERtIA)
no
Old Apr 16, 2006 | 07:04 AM
sc4dr's Avatar
Actually there is a way to cheat a little bit. You can run the belts a little loose, and boost around 4- 5 psi....just dont expect the belts to last 30,000 miles. N/A cams also reduce boost on jrsc apps. Remember that when you reduce boost you're still running on the fuel map for the higher boost so it will run rich.
Old Apr 16, 2006 | 07:35 AM
waveoff's Avatar
What would happen if you forcibly kept the bypass valve open?
Old Apr 16, 2006 | 08:55 AM
Jaker's Avatar
There was an electronic boost controller made for JRSCs that was sold a while back. I don't remember the name of the company but they were highly publicised on ClubSi. It basically used a servo to open the bypass valve to limit boost. I never actually tried it or saw one, but it allegedly worked quite well.
Old Apr 16, 2006 | 05:31 PM
iNERtIA's Avatar
^ yeah thats wat i was thinking.
im running itr cams w/ gsr motor. will that affect boost levels and make it harder to tune?
nigel
Mar 24, 2004 05:29 PM
Aquafina
Jun 25, 2003 10:30 AM
LOwrestling2001
Sep 5, 2002 03:25 AM
2fcknfst
Sep 21, 2001 07:43 PM
