b18b==b18c for swap into 1993 civic dx
Old May 28, 2006 | 08:12 AM
fcrx7zoomzoom's Avatar
Default b18b==b18c for swap into 1993 civic dx
I want to swap a b18b into my civic however i can't find out what parts i am suppose to swap with the engine. Is it all the parts you would swap with a b18c?
Old May 28, 2006 | 03:47 PM
Default Re: b18b==b18c for swap into 1993 civic dx (fcrx7zoomzoom)
A little help would be nice because i have to have this finished by the end of july
Old May 28, 2006 | 04:04 PM
BlueIntegraBoy's Avatar
Just wire up VTEC, KS, and IABs. Use a P72.
Old May 28, 2006 | 04:19 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcrx7zoomzoom &raquo;</TD></TR><TR><TD CLASS="quote">I want to swap a b18b into my civic however i can't find out what parts i am suppose to swap with the engine. Is it all the parts you would swap with a b18c?</TD></TR></TABLE>
Everything is exactly the same except for the wiring and ECU. With the B18B, you dont need to wire in the VTEC, IAB, or knock sensor because the B18B has none of those - basically, you won't need to do any wiring. You'll need an OBD-1 P75 ECU.
Old May 28, 2006 | 04:27 PM
B_CRUZ!'s Avatar
Default Re: b18b==b18c for swap into 1993 civic dx (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Everything is exactly the same except for the wiring and ECU. With the B18B, you dont need to wire in the VTEC, IAB, or knock sensor because the B18B has none of those - basically, you won't need to do any wiring. You'll need an OBD-1 P75 ECU.</TD></TR></TABLE>
exactly.
Old May 28, 2006 | 07:00 PM
NRZero's Avatar
Default Re: b18b==b18c for swap into 1993 civic dx (B_Cruz)
Pretty much with the B18B it just plug and play.
Old May 28, 2006 | 07:53 PM
fmrprojects's Avatar
Default Re: b18b==b18c for swap into 1993 civic dx (NRZero)
just use everything from the integra
motor, tranny, mounts, wirng, shift linkage, axles, headers, intake manifold and throttle cable.
if its a 96 and up , then you are going to need a 0bd-1 p75
HksHaitian
Apr 14, 2005 02:24 AM
lillex
Jun 14, 2004 10:03 AM
jbell
30
Mar 4, 2004 12:48 PM
volleyd13
Dec 30, 2002 03:34 PM
The G2 Racer
14
Aug 15, 2002 05:16 AM
