What is a P30 Head?
Old May 27, 2006 | 05:41 PM
JBirch_97Prelude's Avatar
Default What is a P30 Head?
I am currently rebuiding my OBD1 B18B1 Engine with a P30 head, to OBD2 emissions. My car is a 1996 GSR so it has to have OBD2 Standards. Some idiot changed it to OBD1. Also, can I put a 1996 Oil pump on a 1994-1995 block?
Old May 27, 2006 | 06:05 PM
mr.beeks's Avatar
Default Re: What is a P30 Head? (RippleSound)
p30 is a usdm b16 del sol engine.
and you said it OBD2 emissions has nothing to do with your build up.
except for the crank possition sensor located at the crank itself.
OBD1 sensor located in the distributor.
and yes you could put the oil pump on your block.
Old May 27, 2006 | 08:11 PM
Default Re: What is a P30 Head? (mr.beeks)
Well where do I put the crank sensor? I thought it goes on the oil pump? So I have a B18B1 with a Del sol Head? Will a obd2 engine harness work with it? You seem knowledgable about these things so tell, why wont my wipers stop wiping?
Old May 28, 2006 | 02:57 AM
dcRay's Avatar
A 96+ oil pump will bolt onto your b18b1 but if you are using a obd I ecu, there is no point in doing so because your ecu does not look for that signal.
Old May 28, 2006 | 05:32 AM
Default Re: What is a P30 Head? (dcRay)
I am going to use a P75 A52 ECU. I have the Engine harness, and conversion harness to the ECU from OBD1 to OBD2A. Is there anything else you think I will need?
Old May 28, 2006 | 07:13 AM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcRay &raquo;</TD></TR><TR><TD CLASS="quote">A 96+ oil pump will bolt onto your b18b1 but if you are using a obd I ecu, there is no point in doing so because your ecu does not look for that signal. </TD></TR></TABLE>
LMAO
ecu doesnt look for the signal....
Old May 28, 2006 | 07:31 AM
The thing is I have to have a OBD2 Diagnostic check. If I change the ECU shouldnt I have a crank sensor? I am running a P72 A01 now (1995 GSR ECU) but the Check Engine light is on.
turbo97coupe
Mar 31, 2009 07:44 PM
turbodohcsi
Jan 10, 2005 04:07 PM
aw1234dude
Dec 7, 2004 01:27 AM
blackeg
Oct 12, 2004 03:12 AM
Ehron
Oct 15, 2003 08:14 AM
