Vtec not working!! Any ideas!!!
Old Apr 13, 2002 | 05:22 PM
RenoRacing's Avatar
Default Vtec not working!! Any ideas!!!
Alright, well my Ls/vtec is running great! but vtec wont engage. I have it just wired to a switch like a lot of people do in hybrids. When i have the car off and i hit the switch i can hear the vtec solenoid click. Then when i start the car and hold the rpm's at like 5000 and hit the switch there is no difference in sound or power when i'm driving. It simply isn't pulling. now, i tried another vtec solenoid that worked when on a previous car and the same thing. Where should i start? I have the stock Ls oil pump but i don't think that should matter should it?? I would think that the Ls oil pump would give enough pressure especially since it's hooked up to a switch and not reliant upon the pressure! Any ideas and info would be great!
thanks guys
Old Apr 13, 2002 | 09:21 PM
Zeus Zore's Avatar
Default Re: Vtec not working!! Any ideas!!! (HavokRacing)
vtec will not engage onless you are over some 10 MPH and temp. is over 60DG
Old Apr 14, 2002 | 08:31 PM
RenoRacing's Avatar
Default Re: Vtec not working!! Any ideas!!! (Zeus Zore)
okay well... even when i drive it doesn't sound like it's changing at all and plus, i have it powered directly from the battery to a switch to vtec solenoid so it really shouldn't matter. I don't know what the hell to do. i'm beginning to think that i got some really shitty automatic cams and vtec is just really weaK!! who knows?
Old Apr 14, 2002 | 08:56 PM
riceboy's Avatar
does your speedometer work?
Old Apr 14, 2002 | 10:03 PM
Kamin's Avatar
run it back through the ECU just like stock.
THEN tell us if it works or not.
Old Apr 15, 2002 | 08:57 AM
RenoRacing's Avatar
Default Re: Vtec not working!! Any ideas!!! (KAMiN)
yes my speedo works. I'm running a non vtec chipped si ecu so i can't run it through the ecu.
Old Apr 15, 2002 | 09:38 AM
Zeus Zore's Avatar
then buy a ECU for VTEC !!!??
Corksil
Dec 17, 2009 02:50 PM
green91
Dec 29, 2004 06:43 PM
blackANESE
Apr 17, 2003 05:11 PM
InfamousRS
May 21, 2002 04:09 PM
THE SOUND OF VTEC
Apr 30, 2002 04:14 PM
