oil leak at distributer....?????
Old May 27, 2006 | 09:30 AM
solrickCC's Avatar
Default oil leak at distributer....?????
ok where the distributer connects/bolts onto the block/head.... oil is slowly leaking from there... when i took the distributer off there is no gasket... so is there supposed to be one and how whould i fix something like this.??
Old May 27, 2006 | 10:07 AM
Paxil4x4's Avatar
Default Re: oil leak at distributer....????? (solrickCC)
More than likely its the black o-ring on the distributer. Thats what seals the oil in this area.
Old May 27, 2006 | 10:11 AM
akstunt600's Avatar
Default Re: oil leak at distributer....????? (packthis)
yes u r missing ur black o ring it fits in the groove on ur dizzy
Old May 27, 2006 | 10:24 AM
EK79's Avatar
Default Re: oil leak at distributer....????? (akstunt600)
also check to see if it is the dizzy. sometimes the valve cover gasket may leak near there.
Old May 27, 2006 | 11:46 AM
hondachris1994's Avatar
Default Re: oil leak at distributer....????? (stoopid monkey)
or camseal or possibly vtec selonoid
Old May 27, 2006 | 11:48 AM
Brick Top's Avatar
if theres no black rubber o ring on the distibutor arm, theres suppose to be one.
Old May 27, 2006 | 12:17 PM
solrickCC's Avatar
nah theres a black o ring.... and no this engine isnt vtec.... its the sohc 1.5 d16 i believe. The S model.
Old May 27, 2006 | 12:25 PM
Brick Top's Avatar
Default Re: (solrickCC)
might just need to replace the o ring. or the distributor could have been warped if its been on an engine that was overheated.
Old May 27, 2006 | 01:13 PM
solrickCC's Avatar
ok well when i talked to like auto zone (parts store) they said i have to bring the old one in and they would have to match it up... the only other way i can get one thats like made for that is through honda correct?
Old May 27, 2006 | 01:43 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solrickCC &raquo;</TD></TR><TR><TD CLASS="quote">ok well when i talked to like auto zone (parts store) they said i have to bring the old one in and they would have to match it up... the only other way i can get one thats like made for that is through honda correct?</TD></TR></TABLE>
any parts store should have the o ring. but if not, call honda. they for sure can get it.
Old May 27, 2006 | 10:41 PM
solrickCC's Avatar
well yea every store has to "match it up with the old one" and yet i dont have to old one and honda store is closed sunday and monday (memorial day) and i dont wanna wait till tuesday.
Old May 28, 2006 | 02:23 PM
solrickCC's Avatar
ok the oring on the dizzy was like a flat plastic thingie.... went to the local parts store and they gave me like this rubber circular one. They said it would work.... but im kinda sceptical... hmm we will see.
Old May 28, 2006 | 03:57 PM
jadugartir's Avatar
the original WAS a black round o-ring, over time it hardened and became flat. thats how mine was when i replaced it a few days ago. i had a slow leak as well. i got the OEM honda replacement for 2 bucks from the dealer
CaliforniaDad
Mar 22, 2013 10:10 PM
tk2222
Oct 10, 2009 10:33 AM
Christopherian1982
23
Aug 22, 2009 07:01 PM
macrohard
Aug 11, 2006 05:15 AM
redracer1024
Feb 17, 2006 11:04 PM
