oil leaking.........HELP!!!
My engine is leaking oil from the top...i see a little bit of oil where it is leaking. The engine is all black due to oil and grease, i guess......how can i get rid of that and make my engine shiny?
Re: oil leaking.........HELP!!!
sounds like the infamous valve cover gasket. check all ur seals dizzy o ring,vtec solenoid,cam seal. use dereaser and pressure wash it off and run it alil bit and see where its coming from and fix it.
I would say that the valve cover is the big one, but I had a bad gasket on my vtec solenoid and that thing leaked everywhere. Originally thought that it was the distributor, but bought a can engine bright and cleaned a small portion of my engine to determine the leak.
Also, while it may not be the solenoid gasket itself if the spool valve is not screwed on tight enough that will also cause a nasty leak.
Civiccity03
07-17-2017 04:54 PM
90CivicDaily
12
05-04-2008 10:12 AM
