NO MEMORY ON MY RADIO
HEY EVERYONE OK THIS IS MY PROBLEM I INSTALLED A KENWOOD RECEIVER AND IT DOESNT HAVE MEMORY... EVERYTIME I TURN OFF THE CAR ALL MY MEMORY (STATIONS I SAVED, SETTINGS I SAVED) GET DELETED WHATS MY PROBLEM??...
you might have the constant 12v (yellow wire from HU) mixed up with the ingnition/accessory wire (red wire from HU)...use a multimeter and see what the yellow wire is reading with the car off...if it doesn't read 12v check to see if your red wire is reading 12v with the car off...if so you simply switch the wires...be careful you're not using the illumination wire (if you hooked it up usually an orange or orange/white wire)
If it's not that then check to make sure all your accessories like dome light, cig lighter etc are still working. If not then it's probably a blown fuse.
