Removing Driver's side window switch
Old May 25, 2006 | 01:11 PM
ramoneguru's Avatar
Default Removing Driver's side window switch
I seen to bee having trouble removing the drivers side window switch for my power windows (car is a 1997 Honda Accord Coupe).
I muddled with trying to "pop" it out but I might have scratched it a little. Anybody know how to do this without removing the door panel??
Old May 25, 2006 | 01:53 PM
natedogg643's Avatar
Default Re: Removing Driver's side window switch (ramoneguru)
I don't know if it's the same as my girlfriend's 98 4 door, but there is a screw on her switch panel that is down in the little change holder/finger handle recess thing. I popped off the plastic cap with a screwdriver and then took out the screw - then the whole assembly came out (of course, I did this while taking the door panel off). Hope this helps
Old May 25, 2006 | 02:29 PM
Ross 2.0's Avatar
In a Junkyard near you.
1. Remove the driver's door panel, and disconnect all
connectors.
2. Remove the power window master switch from the
door panel.
3. Install in the reverse order of removal.
Good luck
Old May 25, 2006 | 05:15 PM
02 accord's Avatar
Default Re: Removing Driver's side window switch (natedogg643)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by natedogg643 &raquo;</TD></TR><TR><TD CLASS="quote">there is a screw on her switch panel that is down in the little change holder/finger handle recess thing.</TD></TR></TABLE>
What he said. No need to remove the door panel.
Old May 25, 2006 | 07:39 PM
silentone's Avatar
Default Re: Removing Driver's side window switch (02 accord)
Use a flathead to pry up the whole assembly after unscrewing the screw in the cahnge holder.
aresjay
Oct 17, 2018 01:36 PM
ay_billy
Jan 25, 2011 02:34 PM
Fuster_Cluck
Jan 8, 2008 01:05 AM
Cnu182
Jul 24, 2006 11:48 AM
