Power Window Problem
Old Jul 6, 2006 | 05:29 AM
Cnu182's Avatar
Default Power Window Problem
im no car guru to say the least, but today in my 94 accord, my power window would not come up. instead, and metal wire came out, and would go back down upon pressing the switch. that being said, i have done quite a bit of googling, and it appears i need a new regulator.
I know how to remove my door panel, but am unsure about the next step(s). are there any good graphical tutorials i could use or any other good resources that might be helpful in replacing this? How difficult is it?
All advice and comments are welcome. Thank you in advance.
Old Jul 6, 2006 | 06:12 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Power Window Problem (Cnu182)
1. Remove:
Door panel
Plastic cover
2. Driver's:
Remove the power window switch from the door
panel, then connect it to the door harness (see page
20-26).
3. Carefully move the glass until you can see the bolts,
then remove them.
NOTE: Take care not to drop the glass inside the
door.
4. Carefully pull the glass out through the window
slot.
door.
5. Disconnect the connector, then remove the regulator
through the center hole in the door. (remove the bolts securing the regulator and motor)
Old Jul 6, 2006 | 06:31 AM
Cnu182's Avatar
thank you so much! i already have the door panel and everything off and i just ordered the parts off ebay. I really appreciate it.
is there anything i can do to keep the window up while i wait for the part to arrive?
Old Jul 6, 2006 | 06:47 AM
Ross 2.0's Avatar
duct tape
Old Jul 6, 2006 | 09:35 AM
Cnu182's Avatar
so the plastic cover isn't necessary? can you elaborate a bit more on step 2?
Old Jul 7, 2006 | 08:28 AM
Cnu182's Avatar
okay! got all of that accomplished yesterday, was a bit tricky but i got it all out. Any advice for putting everything back in?!
Old Jul 18, 2006 | 08:17 AM
Cnu182's Avatar
Success! now if i could just get her to stop leaking oil we'd be set..that's for another thread though.
Thanks
Old Jul 18, 2006 | 08:46 AM
Ross 2.0's Avatar
glad you got it all fixed
Old Jul 24, 2006 | 11:48 AM
Cnu182's Avatar
Default Re: (MooGoCow3)
well sorta, sorry to open this up again.
my window goes about half way up pretty steady,
then slows down and jumps the track sorta
I have to go outside of the car and guide it right
so it goes in. any ideas?
aznomb
Honda Civic (2001 - 2005)
Jul 9, 2010 03:46 AM
eg6civic1538
Jun 1, 2007 10:19 PM
fasterthanrayswrx
Jan 26, 2007 04:36 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
