H23 External Distributor Work with H22A?
Old May 25, 2006 | 06:57 AM
NukeeZoid's Avatar
Default H23 External Distributor Work with H22A?
hi, i need a quick answer...
does the H23 EXTERNAL distributor work with a H22A with an INTERNAL distributor?
everything bolts on and plugs in fine. but im not getting any spark.
running the H23 harness with no wiring modifications.
Old May 25, 2006 | 07:07 AM
NukeeZoid's Avatar
bump!
can someone confirm this for me please!!
Old May 25, 2006 | 07:19 AM
Finest's Avatar
Default Re: (NukeeZoid)
It should work. Just remove and replace. You are still using the H23a coil, right?
Old May 25, 2006 | 07:21 AM
NukeeZoid's Avatar
Default Re: (Finest)
right now i have switched it back to the H22A internal coil....and spliced the yellow and black/yellow wires together....
but im still getting no spark from there...
what could be the problem?
Old May 25, 2006 | 07:27 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NukeeZoid &raquo;</TD></TR><TR><TD CLASS="quote">right now i have switched it back to the H22A internal coil....and spliced the yellow and black/yellow wires together....
what could be the problem?</TD></TR></TABLE>
Wait, so are you using an H22a distributor? Or are you using the H23a1 distributor?
And what chassis is this in? 4th Gen Prelude? 5th Gen Civic? The H23a1 distributor should plug in the OBDI harness.
Old May 25, 2006 | 09:09 AM
NukeeZoid's Avatar
chasis = prelude 92 SI....
thats what i thought that it should plug in directly....and function...but there was still no spark
Old May 25, 2006 | 09:22 AM
AndyD's Avatar
I did what you are asking about. Yes, the H23 distributor bolts right on. It is a direct plug and play.
H22A1 and H23 distributoors are the same, and the USDM Prelude is wired to work with the external coil distributor. Making the H22A distributor to work requires some modification.
Old May 25, 2006 | 10:15 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NukeeZoid &raquo;</TD></TR><TR><TD CLASS="quote">chasis = prelude 92 SI....
thats what i thought that it should plug in directly....and function...but there was still no spark</TD></TR></TABLE>
Assuming everything is bolted in correctly, check your distributor for a blown ignitor.
But why did you splice the yellow and yellow/black wires together again? This is at the distributor plugs, correct?
mitchtsiawd
Sep 5, 2006 11:21 AM
NukeeZoid
May 24, 2006 09:05 PM
s2k_al
Feb 21, 2005 06:19 PM
the_eyecon
Sep 10, 2003 06:01 PM
