T3/T4 rebuild
Old May 23, 2006 | 09:51 PM
brad98_teg's Avatar
Default T3/T4 rebuild
Im in the process of rebuilding the turbo I got from my Drag kit. I have both housings off and need to get to the shaft with all of the seals. How may I go in doing this? Im just trying to be safe and make sure I'm doing it right before I screw something esle up.
thanks
Old May 24, 2006 | 04:22 AM
brad98_teg's Avatar
bump
Old May 24, 2006 | 04:29 AM
Chris22215's Avatar
Default Re: (brad98_teg)
you have to remove the nut on the compressor side of the shaft. That will allow you to take the comp wheel off. Then the rest of the shaft is connected to the exhaust wheel.
*If you need a t3t4 rebuild kit, I've got with the 360 degree thrust
Old May 24, 2006 | 04:32 AM
Finland's Avatar
just be careful when you try to loosen the nut, it's reverse-threaded
Old May 24, 2006 | 06:33 AM
brad98_teg's Avatar
reverse thread! thanks that helps
Old May 24, 2006 | 06:39 AM
brad98_teg's Avatar
by the way, are there any tricks or tips to getting the nut off. Im trying to be gentle,but damn that thing is a bitch to get off
Throwdown
Jul 2, 2013 01:45 PM
Dream
Sep 8, 2004 03:01 AM
j-specB20sol
May 11, 2004 10:41 PM
racinskittle
Jun 28, 2003 03:19 PM
AlphaKennyWun
Feb 16, 2002 09:52 AM
