Stock Injector and FMU setup safe?
Old May 23, 2006 | 04:53 PM
Tippyman's Avatar
Default Stock Injector and FMU setup safe?
I plan on boosting my SOHC ZC and plan on using the stock injectors with a FMU setup. (12:1)
On a Tial 38 mm. wastegate with a .5 bar spring, would it be safe to boost at the wastegates stock level?
Old May 23, 2006 | 05:02 PM
crxnj's Avatar
Default Re: Stock Injector and FMU setup safe? (Tippyman)
i dont know what 0.5 bar means,,but if its like ~6 psi you will be fine..just gotta watch out for boost creep....
Old May 23, 2006 | 05:03 PM
Autoworks's Avatar
Default Re: Stock Injector and FMU setup safe? (Mr.speaker)
.5 bar is 7.25psi.
You should run an inline booster pump as well
Old May 23, 2006 | 05:05 PM
crxnj's Avatar
Default Re: Stock Injector and FMU setup safe? (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote">.5 bar is 7.25psi.
You should run an inline booster pump as well </TD></TR></TABLE>
he better..the stock fuel pump cant handle the pressure the fmu needs..
Old May 23, 2006 | 05:16 PM
si0385.'s Avatar
i wouldint use an fmu period even if it was for just low boost... if you get it tunned right you can boost more than that safer than you can 6 psi on a fmu
Old May 23, 2006 | 05:26 PM
crxnj's Avatar
Default Re: (si0385.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">i wouldint use an fmu period even if it was for just low boost... if you get it tunned right you can boost more than that safer than you can 6 psi on a fmu</TD></TR></TABLE>
you can boost more with fmus to..just have to change out discs and get something to take away the fuel (afc for example) and you can get a pretty good a/f ratio..
i agree with you though its better to just get it tuned,,but then not everyone lives by a tuner..
Old May 23, 2006 | 05:43 PM
Tippyman's Avatar
So how can I safely do it?
I was thinking of this setup:
FMU:
http://prostreetonline.com/buy/blox_fmus/
Fuel Pump:
http://prostreetonline.com/buy...-965/
How much should I retard my timing to help make it safer?
Old May 23, 2006 | 05:56 PM
Tippyman's Avatar
Forget it, after searching, I am scared shitless to use an FMU.
Old May 23, 2006 | 05:57 PM
Autoworks's Avatar
Default Re: (Tippyman)
Not knocking, but if you are doing the turbo with budget in mind, both prices on those links are about $20 too high per part ( $40 could make your oil feed)
There's no doubt that tuning is better, but a propper FMU set up is safe.
Old May 23, 2006 | 05:59 PM
Tippyman's Avatar
Default Re: (Autoworks)
you got PM
Old May 23, 2006 | 06:00 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks &raquo;</TD></TR><TR><TD CLASS="quote"> but a propper FMU set up is safe.</TD></TR></TABLE>
A setup such as? How canI do it? What products to buy and how should I set it all up?
Old May 23, 2006 | 06:04 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
A setup such as? How canI do it? What products to buy and how should I set it all up?</TD></TR></TABLE>
FMU
Inline pump (MSD is fine)
Warlboro in tank (if your pump is still stock-I'd replace it anyway)
If your not creeping (which the Tial shouldn't) you should be fine. The Inline pump will make sure that you aren't leaning out under boost and the FMU will make sure your pulling enough fuel, so it works. Everyone knocks FMU's but remeber...Hondata/Crome/Turboedit wasn't always around. Look at alot of off the shelf kits...what do they supply you for fuel in a basic setup (Drag/RevHard)...an FMU and inline pump. If you are really nervice and can't get to a tuner, look for a Greddy blue box used.
But by all means, if you have access to dyno time, or know someone that can street tune/datalog use turboedit.
Old May 23, 2006 | 06:12 PM
Tippyman's Avatar
12:1 FMU ok?
Tippyman
May 23, 2006 05:56 PM
Type-X
Apr 6, 2005 05:37 AM
stinker504
Sep 15, 2003 05:38 AM
boostincoupe
Sep 11, 2003 12:53 PM
88crxvtec
Feb 13, 2003 07:13 AM
