question for people with 3 inch downpipes
Old May 23, 2006 | 11:43 AM
huge230's Avatar
Default question for people with 3 inch downpipes
How do you guys have room for all 5 flange bolts when using a 3 inch pipe? I dont think I am going to be able to make all bolts fir if I use a 3inch pipe
Old May 23, 2006 | 12:03 PM
Finland's Avatar
Default Re: question for people with 3 inch downpipes (huge230)
I have a 5 bolt flange on my 3" dp. You have room, the bottom bolt is always a pita though. I ended up having to use a stud on the bottom one.
Old May 23, 2006 | 12:08 PM
huge230's Avatar
Default Re: question for people with 3 inch downpipes (Mr. Helsinki)
do you happen to have a pic?
Old May 23, 2006 | 12:10 PM
Finland's Avatar
I'll take some for you tonight, the motor is out of the car, but the dp is still there, so it will be easy to see.
here's one I took a couple of years ago. I'll get some better shots.
Old May 23, 2006 | 01:25 PM
huge230's Avatar
Default Re: (Mr. Helsinki)
ok thanks alot
Old May 25, 2006 | 04:50 AM
Finland's Avatar
Default Re: (huge230)
sorry, I was running late for work yesteday (by 1 hour....ooopsie.) so I couldn't get the pics until this morning..
Hope this helps..
One of the things I found helpful was to use 2 of the OEM spring bolts minus the spring on the 2 rear holes, and a stud and nut on the bottom one. Make sure you use antiseize on the threads, otherwise you'll have much difficulty taking them back out.
Old May 25, 2006 | 04:52 AM
huge230's Avatar
thanks alot that
helps me out
Old May 25, 2006 | 08:02 AM
weiRtech's Avatar
OG Fabricator
just don't turn the pipe down right off the turbo. here is mine:
Old May 25, 2006 | 08:13 AM
Finland's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">just don't turn the pipe down right off the turbo. </TD></TR></TABLE>
I had to on mine, I have a/c and p/s.
Old May 25, 2006 | 08:40 AM
hootiehoo's Avatar
weld on a v band flange to the 5 bolt flange.
makes things a lot easier
Old May 25, 2006 | 10:09 PM
HiProfile's Avatar
[url=http://imageshack.us][img]</TD></TR></TABLE>
In the corner, is that a JDM HOE?
If nothing else, either pound in the pipe around the holes, or use 3/4" long flare section of 3" to [2 7/8" or less]. If you think that is bad, try using 3" off a 3 bolt internal gate flange...
Old May 27, 2006 | 03:55 PM
egrice's Avatar
vband
092eg6
Welding / Fabrication
10
Jan 14, 2011 08:21 AM
boosteddb8904
Feb 1, 2008 09:00 AM
Tjabo
Jan 2, 2008 03:55 AM
huge230
Apr 25, 2006 08:49 AM
goose21
Dec 6, 2004 12:05 PM
