quick throttle cable question??
i noticed on my friends type r that his throttle cable came from the left hand side of the firewall, (drivers side ) then went along the firewall, about to the middle where it was held on the firewall by a bracket. the cable then did a 180 turn so it could to attathed to the spring on the thorttle body. i then noticed that the a spring was also different since the cable would pull from the oppesite side.
so my question is : is this just the standard ITR design or something else ?/ if so what is it off of then??
It should come out of the firewall, make a 90 degree turn straight into the throttle body. There should be a bracket on the IM, held on with two 10mm bolts that stabilize the cable.
sk8shorty012
Jun 7, 2008 07:06 PM
itr501
May 8, 2002 05:47 PM
