ball jonits!!!!!!
hey im putting my passenger side lower ball jonit back on and when i get it 4-5 thrads i tighten it down and it starts to spins the whole balljonit.any ideal how to stop it from spining??there brand new not even a year old.
when you undid them did you hit them with a hammerthat can cause this problem what i allways do when this happens is grab the top of the ball joint with some vise-grips and tread the bolt all the way up than try putting it back togeather and see if it does the same thing again
grab the tapered shaft with channel locks or vice grips and get the right size die its 12x1.25 i believe, and run it to clean the threads and the nut will go on like butter, i did this to mine awhile ago and the nuts thread on much easier, or just buy new ball joints
its pretty typical the threads get messed up on either the castle nut or balljoint just enough that they provide enough friction to overcome the friction in the balljoint and tapered surface.
carefully popping off the balljoint and using new castle nuts or retapping them helps.
Juans_MX3
42
Jul 10, 2021 04:38 PM
