TPS Throttle Position Sensor Grounding
Hey everyone, ive been throwing alot of tps sensor codes for too low of a voltage and checked over the wires with a voltmeter and the wire that is supposed to be grounded, the green (which is all the way to the right on the connector if your looking at it) has voltage, has anyone else run into this? could i just ground it elsewhere or does it share a ground with something?
csunny95
Sep 20, 2018 10:15 AM
