auto swap question
i am putting a ls motor and auto trans in my car it is a 95 eg auto dx....the top trans mount is not lining up....has anyone done this kind of swap and if so what trans mount did u use...thanks
Modified by hotlileg6 at 5:00 PM 5/22/2006
why not just try mix-n-matching until you find one that works??
not too many people keep the auto. most that go from auto to manual have to get a conversion bracket of cut/reweld one of the mounts...so that right there will probably tell you straight up that you've got a unique mount on the one that isnt lining up...
well if you do, let me know, I've been wanting to keep the auto and convert over but cant find the info on the brackets.
all the other brackets from the integra work good??
the top trans mount it the one over on the passenger frame rail??
yea every other mount works fine....yea its just the one on the passenger's side frame rail that doesnt line up....the studs coming out of the trans ar to close to the passenger's side....if the were an inch towards the drivers side everything would fit...
joedaddy1979
Feb 5, 2010 05:37 PM
93formula
Feb 21, 2007 11:15 AM
