HELP ABS and Clutch
when i press the clutch in to shift the clutch goes all the way to the floor, but it takes a few times to shift into gear. sometimes it wont even shift into gear.
do i need tranny fluid?
and also when this started to happen my ABS light came on, what do i do to fix it?
thanks
**Edit** THis is for my 95 Lude (H23)
thanks
You need some clutch fluid. Buy two bottles - fill up the abs resevoir - on passenger side - next to fuse box.
Fill up the clutch resevoir also - then you have to bleed the slave. If you need instructions - just ask and we will tell.
Oh - clutch fluid is just Dot3 brake fluid - just to let you know.
all my levels are to the max already
i was checkin my manual and there is a section about changing the oil in the tranny, and it says to undo a bolt to check the level, where is that bolt located?
and how do i drain the brake fluid cause i havent done it since owning the car, i have had it almost 2 years
