alternator issues HELP!!!
I have a 94 civic hatch with a b16a2 my alternator went bad,so I ordered a new 1 from a 94 delso vtec cause they have b16's, my problem is when I put the bottom bolt in the top doesnt line up rt...did i order it from the wrong yr car, cause the 1 that was on there lined rt up.....any help would b greatful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">did you convert to an OBD1 alternator when you did the swap? If you didn't the plugs will be different for sure.
I thought the mounting was the same but I'm not 100%.</TD></TR></TABLE>yes its OBD1 I have it hooked up but with just 1 bolt (top1 )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top end tuner »</TD></TR><TR><TD CLASS="quote">try an alternator from a 99-00 honda civic si those have b16a2 obd2 alternators</TD></TR></TABLE>I did but I have OBD1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top end tuner »</TD></TR><TR><TD CLASS="quote">when you bought the motor did it come with the stock alternator or an aftermarket one</TD></TR></TABLE>I believe it was a stock 1, so I ordered a 94 delso vtec alternator cause it has a b16 and I figured they were the same,I got it hooked upnow eith 1 bolt but like I sais if I put the bottom bolt in the the top part doesnt line up, so I just got the top bolt in for now until I get the rt bracket or alternator
well not the alternator brackets probably because you have an obd1 alternator and are trying to put it on the obd2 motor (p.s. see if you can order a del sol alternator bracket if you can)
Uniquerootz
Oct 2, 2007 11:40 AM
white90rexsi
Jan 2, 2007 07:55 PM
gezer
Sep 3, 2004 05:17 PM
