accord brake light staying on
Old May 21, 2006 | 03:56 PM
mayday3k's Avatar
Default accord brake light staying on
all brake units seem to be working fine, but for some reason the light is staying on.... i dunnoooo its just started today....thanx in advance... btw its a 94 accord
Old May 21, 2006 | 04:06 PM
jmk64's Avatar
Default Re: accord brake light staying on (mayday3k)
Is it the Brake Lamp Light???????
Check your Tail lights might have one out.
Old May 21, 2006 | 04:19 PM
jli18's Avatar
did u mean the brake light indicator?? if so, check the brake fluid if they are low.
Old May 21, 2006 | 04:23 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mayday3k &raquo;</TD></TR><TR><TD CLASS="quote">all brake units seem to be working fine, but for some reason the light is staying on.... i dunnoooo its just started today....thanx in advance... btw its a 94 accord</TD></TR></TABLE>
LOL I have the same problem all the brake lights will work but for some reason the light comes on when you hit the breaks! there is a green wire that I figure is the sensor feed for that feature...it got lose in mine from swapping out the taillights from stock to alcheezas, to stock, to JDM knockoffs, back to stock....either wiggle the wire till its not doing it anymore and tape it in it's happy place, or do what I did and simply take out the bulb because that light is effin annoying!
oh mines a 94 too
Old May 21, 2006 | 11:26 PM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: accord brake light staying on (I got the CD5 Jeebies!)
Brake light indicater usually mean one of your bulbs is bad... Ive had it happen intermittently when one of my bulbs was going bad... Also you may want to check for corrosion in the plug...
Old May 22, 2006 | 06:36 AM
Ross 2.0's Avatar
In a Junkyard near you.
Yea were gonna need to know if it's the "Brake" "Brake Lamp" or the actual brake lights that are staying on
Old May 22, 2006 | 08:29 AM
cambopheonix56's Avatar
Default Re: (MooGoCow3)
If its the one that comes on when you pull the e-brake on the gauge cluster, you are probably low on fulid.
Old May 22, 2006 | 08:37 AM
Default Re: (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">If its the one that comes on when you pull the e-brake on the gauge cluster, you are probably low on fulid.</TD></TR></TABLE>
Really!??? I never knew that but I guess it makes sense there is the oil light indicator when your low on oil......there should be one for low break fluid too!...hmmm I check my car every morning...lights, air, fluid but it's good to know that if one of my buddies has the same problem I now know one possible cause! thanks
Old Jul 24, 2006 | 05:42 PM
LoserKid's Avatar
Default Re: (I got the CD5 Jeebies!)
I just bought a 93 Accord EX and my brake light on the cluster won't shut off I just changed all the pads around the car any ideas? Sorry to jack the thread
Old Jul 24, 2006 | 06:53 PM
honda4674's Avatar
on the 93 accord when you pull the e-brake it pushes down on a sensor for the brake light to come one sometimes over time stuff gets in there or it gets loose and it just needs to be cleand or tightend to make it stay in place if you take off the peice surrounding the e-brake youll see it and that may be it if not im not to sure
Old Jul 24, 2006 | 08:55 PM
LoserKid's Avatar
Thanks alot man I'm going to give that a try as soon as I can.
vic_houston
Feb 17, 2023 03:29 PM
moundsostuf
Feb 28, 2015 09:12 PM
92siracer
Aug 27, 2005 10:11 AM
QuicSS
Sep 7, 2004 12:05 PM
