What ECU for B16a2?
Old May 20, 2006 | 07:45 PM
JDM B16A's Avatar
Default What ECU for B16a2?
I was wondering what is the STOCK ECU for a B16A2 ( USDM B16 ). and will it work for a JDM b16A (first gen)?
Old May 20, 2006 | 07:56 PM
kiddcarbuff's Avatar
p30
Old May 20, 2006 | 08:00 PM
eg6hatch94's Avatar
Default Re: What ECU for B16a2? (JDM B16A)
use p28 obd1 best to chip and tune
Old May 20, 2006 | 08:01 PM
Ls_V_TurboSi's Avatar
the stock b16 ecu is a p2t.. What car is this goin in?
Old May 20, 2006 | 08:27 PM
tek9_ej2's Avatar
use the p28.
Old May 21, 2006 | 12:09 PM
JDM B16A's Avatar
Default Re: What ECU for B16a2? (tek9_ej2)
okay, so i got p30 and now p2t. I'm trying to get my EM1 back to stock! I'm now run'n a P06 chipped for 5spd, DOHC Vtec and aggressive fuel map'n. So, now i'm throwing everything back to stock! I want to know the BONE STOCK ECU for an EM1. Don't really need to know what's good for tune'n or any of that. Just BONE STOCK ECU that came with an EM1! Thank you!
Old May 21, 2006 | 12:32 PM
SkoundrelUSA's Avatar
cute little bastard
P2T is the stock ECU for a EM1. Here's the proof
http://www.thehondapartsstore....ch=no
But, you must be running a conversion harness to be running a P06 so yeah you gotta take out I think
Old May 21, 2006 | 01:22 PM
1.8 tuner's Avatar
it would be best to use a p28 with a jun chip. then get the apexi vafc-2 for tuning.
Old May 21, 2006 | 01:25 PM
cute little bastard
Default Re: What ECU for B16a2? (mugen18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen18 &raquo;</TD></TR><TR><TD CLASS="quote">it would be best to use a p28 with a jun chip. then get the apexi vafc-2 for tuning.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">okay, so i got p30 and now p2t. I'm trying to get my EM1 back to stock! I'm now run'n a P06 chipped for 5spd, DOHC Vtec and aggressive fuel map'n. So, now i'm throwing everything back to stock! I want to know the BONE STOCK ECU for an EM1. Don't really need to know what's good for tune'n or any of that. Just BONE STOCK ECU that came with an EM1! Thank you!</TD></TR></TABLE>
Old May 21, 2006 | 01:28 PM
SiB16A's Avatar
Default Re: What ECU for B16a2? (SkoundrelUSA)
my p2t that is fro sale , 99-00 Si stock ecu's are p2t's, even if you have a first gen motor in there yes it will work. Is everything converted to obd2?
Old May 21, 2006 | 01:37 PM
Relic1's Avatar
P2T = bone stock 99-00 SI (EM1)
SkoundrelUSA's post more than proves that.
pull your OBD2b-OBD1 harness and plug in the P2T.
IF all the sensors are connected right you will have no problems.
NOTE: a JDM B16a is missing at least one sensor that the P2T looks for. The crank speed fluctuation sensor is built into the oil pump housing on USDM engines.
easy to trick into not throwing the code though, one jumper wire is all it takes. I dont' remember off the top of my head which wires to jumper to though. I'm sure if you search it will come up.
Old May 21, 2006 | 04:21 PM
JDM B16A's Avatar
okay, got it! Thanks for your help guys.
tigueremalo
Oct 9, 2007 08:18 PM
tubed-ef
May 2, 2007 11:35 AM
vandersmissenc
Nov 10, 2005 03:50 PM
Bone Stock
Sep 12, 2004 08:46 PM
