JUST CHANGED WATER PUMP/TIMING BELT nothing changed
Old May 20, 2006 | 07:29 PM
DB1_559's Avatar
Default JUST CHANGED WATER PUMP/TIMING BELT nothing changed
ok like the post said but it still overheat timing belts kool any ideas
Old May 20, 2006 | 08:10 PM
old man neri's Avatar
Default Re: JUST CHANGED WATER PUMP/TIMING BELT nothing changed (jdmboi86)
How about you actually describe your problem. It over heats, okay.
When does it over heat? On the highway, in the city, all the time, sometimes, does the fan engage, is there sufficient coolant, any noticible coolant leaks or loss????
Old May 20, 2006 | 08:31 PM
kiddcarbuff's Avatar
check your theromostat...could be stuck closed
Old May 20, 2006 | 09:39 PM
DB1_559's Avatar
oh srry it startin when i was parked and coolant its full the thermosta new but its a 160 degree can that be the cause also im running a auto raditar but ill check the fan
Old May 20, 2006 | 10:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">oh srry it startin when i was parked and coolant its full the thermosta new but its a 160 degree can that be the cause also im running a auto raditar but ill check the fan </TD></TR></TABLE>
Let it just idle for a while. If the fan doesn't engage and it is over heating it will help you pinpoint the problem. As for the T-stat, it is best to always go with OEM because you know it is for the right temperature. When you replaced it/changed your water pump did you make sure you got all the air out?
Old May 21, 2006 | 03:25 AM
thahuhstunna's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">ok like the post said but it still overheat timing belts kool any ideas</TD></TR></TABLE>
what?
Old May 21, 2006 | 07:08 AM
PePe240sx's Avatar
Default Re: JUST CHANGED WATER PUMP/TIMING BELT nothing changed (thahuhstunna)
II think he is saying that the timing belt is working properly, but the car still overheats with the new water pump.
To the original thread starter, did you bleed the system correctly?
Flipmonkey
Sep 30, 2013 06:54 PM
johnny090881
27
Jun 8, 2009 01:19 AM
Utilitarian
Sep 14, 2007 11:20 AM
erek9
Jun 20, 2005 07:20 PM
MetalGunSI
Jun 12, 2003 09:25 AM
