bad IACV or TPS
Situation: I have a b16 turboed EK with AEM. During normal start up is fine. After a long drive on the freeway, the car start to surge 2000 rpm to 3500 rpm. I stopped the car and unplug the IACV plug and the car idle at 2000 steadily. I drive the car home and put on a new but used IACV and the car started up fine with no surges. After that, I take th car for a drive again. The same thing continues WTF. I check my TPS voltage and it's fine. I checked the Vacuum and it's also within spec. My car does not have the FITV. It's a BDL 70mm throttle body. This just drives me crazy. I have replaced the thermostat and radiator cap too. Bled all air out of the system. Have any suggestion? Can timing put it out of sequence?
SeaBass
Jul 3, 2003 07:46 AM
