gauge cluster stoped working
Old May 19, 2006 | 07:09 PM
hedtrip's Avatar
Default gauge cluster stoped working
today i was driving around & my Gauge cluster stoped working .
everthing but my Speedo . but no tach , fuel , temp . or CEL . & allso my blinkers arent working . but my hazards are .
what would cause this . i seached but couldn't find some1 with the same prob
. would it be a relay ?
Old May 19, 2006 | 07:29 PM
daidilus's Avatar
check all of your fuses!!
Old May 19, 2006 | 07:30 PM
hedtrip's Avatar
Default Re: (daidilus)
i pulled them all
Old May 19, 2006 | 07:40 PM
bustedefhatch's Avatar
Default Re: (hedtrip)
under hood fuses too? does it light up when you turn the lights on? the spedo works cause it cable not electrical so im guessing a wire shorted it all out. check the wires and plugs on the back its super easy to take off.
Old May 19, 2006 | 07:50 PM
hedtrip's Avatar
Default Re: (bustedefhatch)
yea i tryed those fuses too . & the backlight comes on , i took the cover off to make sure everything was still pluged in . but didn't inspect every wire , it's to dark . right now .
Old May 19, 2006 | 07:53 PM
it stoped working while you were driving? did you hit a bump or something? maybe try a friends cluster too.
Old May 19, 2006 | 08:03 PM
hedtrip's Avatar
i was driving to go to get my car tuned . & i hit alot of bumps on the way . but no more then ussal . i think my frined has a spare one but he's out of town tell next friday ..grrrr
Old May 20, 2006 | 06:41 AM
hedtrip's Avatar
bump!
Old May 20, 2006 | 06:25 PM
hedtrip's Avatar
i tryed a diff gauge & still same thing !
Old May 20, 2006 | 06:42 PM
wood 1's Avatar
You need to use an exact cluster swap because wiring is different for different clusters. Don't let people tell you they are the same for that year because they aren't. 2 cluster manufacturers and different pin outs. either get the same cluster or rewire to match.
Old May 20, 2006 | 06:44 PM
wood 1's Avatar
What part of Memphis are you in ? I lived in Raleigh/ Millington back in the 80s
Old May 21, 2006 | 06:14 AM
hedtrip's Avatar
Default Re: (wood 1)
no i used one from a 89 dx . i've miitched matched dff gauge cluster from diff years & trims & never had a prob.
i live in south memphis next to the Fedex.
now my backlight wont come one
Old May 22, 2006 | 02:19 PM
hedtrip's Avatar
bump !
Old May 22, 2006 | 04:01 PM
ludesrv's Avatar
I had the exact same problem. It was a blown fuse. Replace the tach fuses and check. Sometimes I fuse can be blown without looking like it is.
Old May 22, 2006 | 06:08 PM
hedtrip's Avatar
whitch fuse is the tach fuse ? i dont see any that say .tach . or gauges . or anything like that ?
Old May 22, 2006 | 08:02 PM
hedtrip's Avatar
ok i fell like a idiot i looked over everyfuse like 3 time . i changed out my turn signal fuse , & it didn't look blown . & it worked thanx !!
d16trexin
Oct 7, 2013 05:44 PM
sleep_Rx
Dec 6, 2007 01:21 PM
Mister Jew
Sep 22, 2006 05:55 PM
j_kevin_ca
Dec 23, 2004 12:56 PM
st0nedstoopid
Oct 19, 2003 07:40 PM
