gauge cluster stop working
Old Dec 27, 2008 | 11:34 AM
d16trexin's Avatar
Default gauge cluster stop working
hey i got a 89 honda crx si and i need to figure what went bad on my car. i was leaving the bar the other night and i had been having problems in the past with my turn signal switch sticking and not always wanting to light up in the down position only unless i shook it around a little but this would rarely happen. so anyway's im leaving the bar i go to signal and nothing both way's up and down then i noticed my whole gauge cluter isn't working excepct the speedometer. tach,temp and fuel gauge were all down and not working. the cluster lights was working still but nothing else except the speedometer. do yall think my cluster just all of a sudden went bad and i need to get a different one or could it be something else.
Old Dec 27, 2008 | 03:42 PM
mouab18c1's Avatar
Default Re: gauge cluster stop working
Check for loose ends
Old Dec 27, 2008 | 05:50 PM
fcm's Avatar
fcm
Old Fart
Check the fuse, then the plug on the back of the cluster, if you have a multimeter or test light you can check for power to the gauges at the plug(s) probably a yellow lead, [sorry do not have an 89 CRX wire schematic]. 94
Old Dec 29, 2008 | 10:56 AM
d16trexin's Avatar
there's is not a fuse for the actual gauge cluster to work,there is a fuse for the cluster lights but they work.can i use any guage cluster from a 88-91 crx,civic hatch, sedan
Old Dec 30, 2008 | 05:55 AM
fcm's Avatar
fcm
Old Fart
No fuse????
All 12V+ wiring in your car has a fuse, the fuse may protect more then just the gauges, but there is a fuse.
Pull the cluster and test for power at the cluster plug(s). 94
Old Jan 3, 2009 | 04:46 PM
91rexb18a's Avatar
would really like to see this one get figured out... i have a 91 with a b18a and the exact same problem i have been searching for about 3 weeks and still can not find the problem i have checked every wire for burns and corrosion also changed the gauge cluster and ecu... only difference is when mine went out i lost everything and my car died thought i had a bad altenator because everything slowly went off and sputered and quit.. changed the battery and the only thing working is the spedo ( of course because of the fact that it is a cable spedo, and the battery light... and the acctually lights that light it up... the fuel gause just started working but it is intermitten, still no other lights or gauges working.... i have been surviving on a oil pres gauge and a water temp gauge both after market on the pillar, would really like for it all to work again... i have unpluged everything and even pulled my dash... nothing... if anyone knows how to get rid of this gremlin that would be great...
Old Jan 4, 2009 | 07:28 AM
fcm's Avatar
fcm
Old Fart
Have you checked for power to the cluster at the cluster plug? 94
Old May 3, 2010 | 02:23 PM
lsrracer's Avatar
If you know what wrong with that can you email to me at tsab_86@hotmail.com cause i got that rite now and cant find want wrong with it. help plz. Thank you.
Old May 4, 2010 | 09:19 AM
T.Sewell's Avatar
Old May 11, 2010 | 02:40 PM
satesh123's Avatar
i did a 95 Acura integra auto to manual and all my guages was working fine until one day i was hiding wires from the auto shifter and the rpm and speed guage stop working? any idea
Old May 11, 2010 | 05:50 PM
fcm's Avatar
fcm
Old Fart
Come on guys, TEST FOR POWER at the cluster plug(s), you can use a $3 test light, Look for lead that has 12V+ when ign switch is in the run position, or engine running.
You will not find the problem without starting with this most basic test.
If cluster lights is the problem, check for power at the cluster plug(s) red/black lead when park/head lights are on, there should also be a ground, [variable] on a red lead, continuity will change as you turn the "Dash Lights Brightness Controller". 94
Old May 15, 2010 | 09:49 AM
lsrracer's Avatar
I check for power at the cluster plug but no power and i check at the engine harness plug and it all have power after that i dont know what to check or do
Old May 15, 2010 | 11:59 AM
michaelguild13's Avatar
Fixed!
Problem: all gauges stopped working except for the Speedometer plus turning signals stopped working. what still worked was the High beams, dimmer, head lights.
( my car is a CRX '90 SI )
Solution: check the fuse box for the car ( the fuse box that is right under the steering column). Check the fuses.
Apparently, if one of the fuses is burned out then the rest of the cluster stops working. For my case, it was the signal fuse. The signal fuse was the only fuse that burned out. I replaced it, turned on my car and wa-la. Everything is back to normal and working properly!
I hope this helps you guys out there.
Old May 17, 2010 | 11:00 PM
lsrracer's Avatar
I check the fuse box all fuse work none is burn but when i use my test light the onlly light that come on is my sun roof and the signal light..... all the light on the bottom is not working but those 2...
Old May 29, 2010 | 06:51 PM
copternadley's Avatar
sensor or gauge issue. or maybe a heavy wiring fault. try using AutoMeter gauges as it is accurate and durable
Old Nov 3, 2010 | 11:25 AM
lsrracer's Avatar
it was my turn signal relay thank you
Old Oct 7, 2013 | 05:44 PM
linkfan665's Avatar
I have a similar problem I drove my 91 si around the block one day and the dash stoped working I checked the wires and it all looks good and so I swaped with another cluster and it worked for about 5 mins. Then stoped working any suggestions?
sleep_Rx
Dec 6, 2007 01:21 PM
P@@RB@Y
Nov 22, 2006 03:29 PM
project ak
Jul 28, 2006 02:33 AM
hedtrip
15
May 22, 2006 08:02 PM
Racersky
Audio / Security / Video
Nov 16, 2005 11:45 AM
