Brakes 91 CRX SI
Old May 19, 2006 | 04:54 PM
mafusmoker's Avatar
Default Brakes 91 CRX SI
I CHANGED THE MASTER CYLINDER AND BLEED THE BRAKES ON THE CAR. THE BRAKES FELT PERFECT UNTIL I CHANGED THE BOOSTER CHECK VALVE,NOW THE BRAKE PEDAL GOES SLOWLY TO THE FLOOR. DO I NEED TO BLEED THE SYSTEM AGAIN?
THERE IS NO LEAKS ON THE LINES. WHAT ELSE CAN BE WRONG?
Old May 19, 2006 | 05:51 PM
EF_ST@TUS's Avatar
oo I have same prob only the going t the floor prob, I think you need to bleed brakes again. I'm not positive tho..
Old May 19, 2006 | 05:53 PM
CR-V-tech's Avatar
Default Re: (Lost_in_a_world_so_cold)
your booster is shot, the reason it's slowly going to the floor is because the daiphram in the booster has a hole, in it and the vacume is bleeding off! replace the booster!
Old May 19, 2006 | 06:04 PM
mafusmoker's Avatar
Default Re: (CR-V-tech)
but I changed the master and evrything was fine until I replace the checkvalve which was ok but since I already ordered I decided to install>
Old May 19, 2006 | 06:18 PM
ED609's Avatar
Default Re: (mafusmoker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafusmoker &raquo;</TD></TR><TR><TD CLASS="quote">but I changed the master and evrything was fine until I replace the checkvalve which was ok but since I already ordered I decided to install&gt; </TD></TR></TABLE>Replace the new chkvalve w/ the old one. If that don't work, bleed the brakes. If that don't work,take the mastercyl off and double check your work.(No offence) If you can't see the problem there. Check the lines for leaks. No leaks? Hand-check the booster. Or vacuum-check the whole system w/ Mighty-Vac Tester. Somewhere somethin got messed up. Sorry.
Old May 19, 2006 | 06:19 PM
ED609's Avatar
Default Re: (ED609)
It's a drag but, eventually you'll find the problem.
Old May 19, 2006 | 06:23 PM
mafusmoker's Avatar
Default Re: (ED609)
you read my mind! I will replace tha valve, and if &gt; bleed the brakes again. About the master, it work find for about a week until i change the check valve, so ido not think it is bad. if nothing work, i will have to change the boster, I'm not loosing any fluid at all
Old May 19, 2006 | 06:53 PM
EF_ST@TUS's Avatar
Same problem about to be fixed going to the 90-93 integra booster/MC with 4040 prop.
uses0ap
Oct 21, 2008 11:22 AM
LAKER HATER
Oct 22, 2005 01:33 PM
I_love_my_HONDA
Apr 24, 2005 07:34 AM
MikeySpec
Jul 18, 2004 04:03 PM
