problem with the brakes...
Old Oct 21, 2005 | 06:33 AM
LAKER HATER's Avatar
Default problem with the brakes...
my sister's 91 integra's brakes are actin up.
when she presses on the brake pedal, she has to do it hard and step on it almost completely to the floor. sometimes, it gets stuck before it slowly comes back up. brake master cylinder problem? i was thinking maybe theres an air leak in the brake lines...
Old Oct 21, 2005 | 06:46 AM
BlackLudeSi's Avatar
Default Re: problem with the brakes... (LAKER HATER)
Correct on both, could be a bad master or there could be air in the lines or both. Bleed the brakes
Old Oct 21, 2005 | 06:48 AM
LL2009's Avatar
Default Re: problem with the brakes... (BlackLudeSi)
most likely is the master cylinder.
Old Oct 21, 2005 | 06:51 AM
ghostrider dc2's Avatar
1)bleed the system
2)if it still does it replace the master cylinder.
DON'T LET 'ER DRIVE THE CAR UNTIL ITS TOTALLY FIXED!
Old Oct 22, 2005 | 09:45 AM
do you know where i can find a "how to" on bleeding the brakes? maybe im doin something wrong lol
Old Oct 22, 2005 | 11:12 AM
::MYCORD::'s Avatar
Default Re: (LAKER HATER)
I believe Team-integra.net has a tutorial on how to do that
Old Oct 22, 2005 | 01:33 PM
pny1981's Avatar
It is really easy if you have two people. You will need a clear hose that fits over the bleeder valve. A bucket, and a turkey baster. First use the baster to drain the master cylinder. Second add new fluid to the master cylinder. Start with the whell farthest from the master cylinder, the right rear. Have your friend pump the brakes untill new gold fluid comes out. Repeat with left rear, front right and front left. Works really well with ate super blue fluid since the fluid is a different color.
jofat91
May 14, 2011 10:40 PM
bigrob119
Oct 18, 2009 04:02 PM
pedroa06
Sep 3, 2009 06:23 PM
94lspower
May 19, 2007 08:42 PM
y49crxsi
Jul 16, 2004 02:14 PM
