cam gears arent sitting right
Old May 19, 2006 | 12:37 PM
raiden571's Avatar
Default cam gears arent sitting right
last night i decided to itall the timing belt on my motor and i realized tht when the motor is at TDC and the cams are lock ed into place, my cam gearss are not straight up and down. both of the cams are positioned this way. now i am running an lsvtec with a b16 head, gsr cams, skunk2 cam gears. the oil pump is from a type r integhra, a new ls water pump and the ls crankshaft gear. is this normal? nothing binds up when u rotate the engine and nothing hits, so i dont know what to do. both sit exactly like that and both are pointing the exact same way and direction. is it just the cam gears thats a little odd?
killacam661
Feb 11, 2010 09:07 PM
b20beast83
Sep 2, 2008 04:21 AM
raiden571
May 20, 2006 06:37 PM
turbodohcsi
Nov 4, 2005 05:37 PM
JDM00SI
Feb 11, 2005 10:34 AM
