Yesterday's project
Old May 19, 2006 | 09:06 AM
onefstek's Avatar
Default Yesterday's project fuel tank sump
Well I got some time to pull off the tank and make a sump for the tank. Here are a couple of pics.
Modified by onefstek at 4:10 PM 5/20/2006
Old May 19, 2006 | 09:55 AM
WillieWillieFast's Avatar
Nice work. Looks good
Old May 19, 2006 | 12:50 PM
onefstek's Avatar
I wish I would have taken a few pics before I welded the sump on.
What I did, is drilled three 2.5" holes in the oem tank, so I have some kind of baffeling between the sump and the oem tank.
Old May 19, 2006 | 01:56 PM
SockEG6's Avatar
Default Re: (onefstek)
looks good.
stupid question... Why do you have to baffle it?
Old May 19, 2006 | 04:05 PM
Motorhead_AZ's Avatar
Default Re: (SockEG6)
Good work, looks nice!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SockEG6 &raquo;</TD></TR><TR><TD CLASS="quote">looks good.
stupid question... Why do you have to baffle it?</TD></TR></TABLE>
So the fuel doesn't "jump" out of the sump between shifts.
Old May 19, 2006 | 07:49 PM
onefstek's Avatar
Default Re: (Motorhead_AZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorhead_AZ &raquo;</TD></TR><TR><TD CLASS="quote">Good work, looks nice!
So the fuel doesn't "jump" out of the sump between shifts.</TD></TR></TABLE>
Yes thats why you want to have some kind of baffles, that way the fuel dosent run all the way forward when shifting, or cornering.
Old May 19, 2006 | 07:53 PM
SockEG6's Avatar
cool. thanks for clearing that up, I kinda figured it had something to do with the movement of the gas.
Old May 20, 2006 | 08:45 AM
onefstek's Avatar
no problem.
I also have to say, that the project was easyer than I thought it was going to be.
Old May 20, 2006 | 05:27 PM
xerox445's Avatar
is your gas tank gauge going to read inaccurately now?
Old May 20, 2006 | 06:09 PM
onefstek's Avatar
Default Re: (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">is your gas tank gauge going to read inaccurately now?</TD></TR></TABLE>
I guess its going to read a bit different, im going to have a bit more gas than what the gauge shows.
Old May 20, 2006 | 07:13 PM
onefstek's Avatar
Today, I got the fuel pump and filter installed, and routed the fuel line to the eng. bay.
Old May 20, 2006 | 09:42 PM
b00stedscotty's Avatar
good work
Old May 20, 2006 | 09:47 PM
onePOINTsix's Avatar
Default Re: (b00stedscotty)
looking good man! BTW what kinda of car is this? looks kinda like a EK maybe
Old May 21, 2006 | 05:40 AM
onefstek's Avatar
yes this is for my Ek.
Old May 21, 2006 | 08:02 AM
JCushing's Avatar
why not a fuel cell, i mean it looks great man but youd be able to shave some weight taking out the tank.
Old May 21, 2006 | 08:27 AM
onefstek's Avatar
^^^ I would have done a fuel cell, but the car is still a daly driver and when I race, I am not allowed a fuel cell in my class.
Old May 21, 2006 | 11:53 AM
JDMCRX's Avatar
Default Re: Yesterday's project fuel tank sump (onefstek)
Nice work man
Old May 21, 2006 | 01:58 PM
tepid1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">Today, I got the fuel pump and filter installed, and routed the fuel line to the eng. bay.
You need to have the pump at the same height or lower than the sump.... This is the purpose if sumping the tank because it is not a puller type pump that you are using. You will see that you will have fuel feed problems.
With the way you have it setup now (about the halfway mark up the tank is about where the pump is mounted) you will have to maintain more that a half tank of fuel to have a positive pressure at the pump inlet.
All in all just lower the pump and you will be straight.
I will be doing this next week with the same setup as you, but in a DC2.
Old May 21, 2006 | 06:11 PM
onefstek's Avatar
and a quick update on the pics.
Old May 21, 2006 | 06:18 PM
SockEG6's Avatar
are you running a K series? or did you keep the return line at the top where the original pump goes?
Old May 21, 2006 | 06:39 PM
onefstek's Avatar
^^^ im going to run the oem feed line as a return.
Old May 21, 2006 | 06:49 PM
SockEG6's Avatar
ahh ok. i see
Old May 21, 2006 | 09:54 PM
tek_civic's Avatar
what do you think about the pumps location as stated above? is this going to be a problem for you?
Old May 22, 2006 | 06:56 AM
onefstek's Avatar
Default Re: (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">what do you think about the pumps location as stated above? is this going to be a problem for you?</TD></TR></TABLE>
I dont' think its going to be a problem. I tested the pump to see if it works, when I had the car's rear end on jacks. I put it about 3 gallons of gas in the tank and it pumped out allmost all of it. But I will have to see how it works in the real world.
I also seen many drag cars that have the pump higher than the fuel cell, and never created a problem for them. So I really think im going to be ok. I really want to keep the pump as high off the goround as I can.
When I do go race, I usually keep about half of tank of gas. That way I have enough for the whole afternoon. So I don't have to pay the real expensive gas prices at the track.
Old May 22, 2006 | 06:58 AM
ejwan's Avatar
nice work.
