Another Auto To Manual Wire Harness Question
Ok I am using my 97 CX AT harness and I am swapping in a D16Y8 Manual. now I know i have to pigtail all the extra connections. Now are tehre any existing wires on teh harness i can use to make the extra connections or do I need to go find some new wires.
For Example, on Plug B that isnt being used in manual should i use any wires from that?
you mean if you have extra automatic plugs can you use those wires and ecu pins for other sensors like vtec and oil pressure sensor, yes you can but dont get confused about wire colors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">you mean if you have extra automatic plugs can you use those wires and ecu pins for other sensors like vtec and oil pressure sensor, yes you can but dont get confused about wire colors.</TD></TR></TABLE>
Thanks!, if i do that i am going to label them at the ECU so i dont get confused
Fuster_Cluck
Apr 17, 2003 01:46 AM
