d15 swap
Old 07-02-2009, 05:20 AM
ej8ster96's Avatar
Default d15 swap
i have to put the d15b7 in my car for now, and i cant find a wire harnes, i found one but its for and auto, can i make it work, if so how
Old 07-02-2009, 06:10 AM
ej8ster96's Avatar
Default Re: d15 swap
need help ASAP
Old 07-02-2009, 06:11 AM
I'm not Rick!
rick_rabies's Avatar
no. way dif wires. gl
Old 07-02-2009, 06:12 AM
ej8ster96's Avatar
the wires are way different from a auto to manual??
Old 07-02-2009, 06:30 AM
ej8ster96's Avatar
anyone else, is it possible to use a auto wire harness off a d15b7, on a manual d15b7?
Old 07-02-2009, 08:33 AM
ej8ster96's Avatar
help please
Old 07-02-2009, 09:48 AM
hannslebo's Avatar
just get on ebay/craigslist...and look up HONDA CIVIC engine harness....make sure its a manual. im pretty sure any D series manual harness will work.......
Old 07-02-2009, 09:50 AM
92lxsleeper's Avatar
it will work. you just can't hook up the TCC solenoid (cause you dont have one on a manual. and you will have to run a custom wire to wire up the reverse lights.
Old 07-02-2009, 09:55 AM
hannslebo's Avatar
get something like this and do it legit...no extra wiring...and you'll be able to use this for any D and B...unless you get VTEC
http://cgi.ebay.com/ebaymotors/92-93...Q5fAccessories
Old 07-02-2009, 10:23 AM
ej8ster96's Avatar
i would go ebay but i have to have the car running this weekend, and i have searched craigslist, and all i can find is one for an auto, not any w/h will work, has to be obd1, i only have obd2
Old 07-02-2009, 10:24 AM
ej8ster96's Avatar
how do i wire up the reverse lights. so i can just get a auto w/h and it will just hook up and im good to go
Old 07-02-2009, 10:26 AM
esean93's Avatar
im useing b18b1 auto engine harness with my 5 speed and mine runs perfect.u might have some extra plug auto plugs layin around the engine bay but itll work.
Old 07-02-2009, 12:14 PM
ej8ster96's Avatar
thanks!!
Old 07-02-2009, 02:13 PM
New User
94hondacivic4dr's Avatar
i have the main w/h out of a '94 Integra LS 2 door with 5 speed and an engine w/h for a D15 out of a '94 Civic DX 4dr 5 speed(i also have the main w/h for that but it had water damage) ...let me know if u need anything elce for a 92-95 Honda Civic 4dr or Integra 2dr and ill let you know it i still have it or not
Old 07-02-2009, 06:36 PM
ej8ster96's Avatar
yeah, i might need that civic harness, is it for a non vtec engine?
Old 07-04-2009, 09:33 AM
New User
yes it is
Old 08-27-2009, 12:28 AM
New User
yoshitunes's Avatar
Post Re: d15 swap
to wire up reverse lights with a auto harness: there should be a plug on your tranny with a yellow wire and a green wire. run those wires inside the car, you have to wire them up to the tranny switches next to the gear box. the tranny switches have a big yellow wire and a big green wire, tap the wires from the tranny plug together (green to green, yellow to yellow) your reverse lights should work!
Old 08-27-2009, 05:06 AM
helldriver88's Avatar
m/t D15B7 engine harnesses are in junkyards all the time. also, OBD1 B18B1 engine harness will work. i think its the exact same thing.
Dukie432
04-18-2009 09:48 AM
JokerX-1.6T
08-22-2006 07:59 PM
93turbo16
07-08-2004 10:51 AM
yellowciv11
04-02-2003 03:03 AM
Quick Reply: d15 swap
