Hay, Help With timing belt
Old Apr 11, 2002 | 07:59 PM
Si_LuDer's Avatar
Default Hay, Help With timing belt
Does anybody have a relatively detailed explanation on how to change the timing belt. It's almost due for my car to do the timing belt.
All Help appreciated
Cheers
Old Apr 11, 2002 | 08:06 PM
Si_LuDer's Avatar
Default Re: Hay, Help With timing belt (GrooVe)
forgot to mention this is for a 4th gen Si 2.3 dohc
thanks again
Old Apr 11, 2002 | 08:09 PM
EP3_05's Avatar
Here is an explanation of how to change the belt on a b18c1. It should give you an idea of what is involved in changing the belt on a dohc motor.
http://www.c-speedracing.com/howto/t...elt/tbelt.html
[Modified by 91civic, 12:09 AM 4/12/2002]
Old Apr 12, 2002 | 03:35 PM
dbman96's Avatar
New User
Please tell me you've purchased a Helms manual for your car before you decided to change your own timing belt.
Old Apr 12, 2002 | 03:44 PM
AzG35's Avatar
A H series timing belt is much different than a B series. I would strongly suggest getting a factory manual or having professional help. H series are a bitch when you have to try to figure things out without help.
Old Apr 12, 2002 | 04:29 PM
Prelude Vtec 23's Avatar
changing the timing belt on prelude motors is a pain in the ***!! Its easier on b motors. You might be better off having someone do it for you. If you decide you wanna do it yourself get the book and good luck!!
hondaaccordf23
Aug 19, 2012 10:05 AM
07pilot
Engine Management and Tuning
Nov 2, 2011 05:41 PM
TheCrimsonGhost666
Oct 10, 2010 01:10 PM
JDMs1eeper
Jan 10, 2006 04:29 PM
H23preludeSi
May 6, 2004 07:03 AM
