***HELP!! Open stud stuck in the back of my block/ EJ coupe
Old May 17, 2006 | 02:18 PM
.kyle's Avatar
Default ***HELP!! Open stud stuck in the back of my block/ EJ coupe
hey you guys. . . i've come to the end of a road. . i dont know what else to do. . i tried to use a cheap oil feed line kit. with an open stud and a brass t fitting. . the problem is that i threaded it in. . then bought a new oil line kit from stealthmode. . so i needed to take the t fitting and stud out. . well the t fitting came off. . and now the stud is stuck in the back of my block. . i have tried so much to get this thing out. . i have pictures right now of me drying a bolt onto the end with JBweld. . i also tried using two nuts interlocked. . unfortunately there arent enough threads sticking out for that. . so i even tried to JB behind one nut but that seemed to fail also. . .i also tried using an "easy-out" BUT there is such limited room behind my block that i cant fit anything back there to un-twist it out. . . THE STUD IS DIRECTLY ABOVE WHERE YOU WOULD PUT THE OIL FILTER. i need any other suggestions you have on how i can get this out of my engine!!! so i can run my turbo civic!! THANKS FOR THE HELP!!
here are the pics:
sorry for the bad pictures. .
Old May 17, 2006 | 02:25 PM
RICE POLICE SIP's Avatar
Default Re: ***HELP!! Open stud stuck in the back of my block/ EJ coupe (IWantATurbo)
I still don't understand what you did? Why is there a bolt in there and what is that brass piece? Where you trying to ghetto rig something?
Old May 17, 2006 | 02:30 PM
.kyle's Avatar
Default Re: ***HELP!! Open stud stuck in the back of my block/ EJ coupe (RICE POLICE SIP)
well i was going to ghetto rig a oil feed kit for my turbo set up. . but decided not to. . just trying to un screw that stud out somehow. . there is a bolt so i have something to turn with a 3/8"
Old May 17, 2006 | 02:39 PM
Luserkid's Avatar
You should be able to put a wrench on it and twist it out slowly. Put the wrench on the brass not your bolt.
Old May 17, 2006 | 03:37 PM
.kyle's Avatar
Default Re: ***HELP!! Open stud stuck in the back of my block/ EJ coupe (Luserkid)
bump
Old May 17, 2006 | 03:43 PM
93allmotorcoupe's Avatar
You could always try grabbing at it with a vice grips and twisting it out, but make that your last resource. And as someone else said, grab by the steel not the brass.
Old May 17, 2006 | 05:39 PM
eXcelonTypeR's Avatar
Default Re: ***HELP!! Open stud stuck in the back of my block/ EJ coupe (93allmotorcoupe)
You could try using a punch to make an notch that you could use the punch against to get it out?? You only need to get it to move about a quart to a half turn then you'll be able to wrench it out. I work as a car wrecker and deal with rusted on nuts and bolts all the time. That's usually what work best for me on large bolted on items.
SAMCRO08
Apr 24, 2012 02:51 PM
.kyle
May 18, 2006 08:46 PM
.kyle
May 18, 2006 12:10 AM
ls95hatch
Jul 18, 2004 10:49 AM
blackeg
Jun 5, 2004 10:18 AM
