Measuring oil: hot vs. cold engine
Old May 14, 2006 | 04:03 PM
ildknyli's Avatar
Default Measuring oil: hot vs. cold engine
About 2 days ago when I drove my car Vtec kicked really hard, and driving it yesterday Vtec was really weak...so i checked the oil hot and it was over a half a quart and checking it this morning cold it was at the full line. Whats the deal? I never noticed this, IICR usually measuring hot yeilds the same results as cold.
ITR / Mobil 1 5w30 synthetic.
Old May 14, 2006 | 05:53 PM
95LssTeg's Avatar
Default Re: Measuring oil: hot vs. cold engine (ildknyli)
oil expands when it heats up. so do the internal parts of your motor
Old May 14, 2006 | 08:06 PM
Ruben19's Avatar
when the engine is runing, oil is all over the motor.
oil level should be check when the engine is cold
Old May 15, 2006 | 05:56 AM
spoonek9's Avatar
Get engine to normal operating temp, then turn off the engine and wait 5-10 minutes. Now check your oil, I believe the owners manual states something similar to this.
Old May 15, 2006 | 09:03 AM
ildknyli's Avatar
Default Re: Measuring oil: hot vs. cold engine (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 &raquo;</TD></TR><TR><TD CLASS="quote">Get engine to normal operating temp, then turn off the engine and wait 5-10 minutes. Now check your oil, I believe the owners manual states something similar to this. </TD></TR></TABLE>
When I do this it still reads above normal.
Old May 15, 2006 | 05:18 PM
95LssTeg's Avatar
This is correct. The oil level will always read higher when the motor is at normal opperating temp as long as all the oil has drained back down into the pan This is due the fact the oil expands as its temperature rises. So one would assume that since your dipstick is reading that your oil is above full, you can probably safely say you have overfilled your oil
B16b-EJ8
16
Mar 11, 2008 06:00 PM
TypeRuz
May 12, 2004 12:38 PM
Motts
Dec 5, 2003 11:41 PM
Qwikrex
Dec 11, 2002 03:05 PM
Blue teg
Dec 4, 2001 06:07 AM
