couple ?s, feedback greatly appreciated
Old May 14, 2006 | 01:26 PM
mymeatb18
Default couple ?s, feedback greatly appreciated
1. I bought a DA with some aftermarket pulleys but im swapping the motor and i wanted to know if the pulleys will work on my b18c block.
2. To use a obd0 b16 oilpump in my completely bare b18c block (except for crank) i have to use the obd0 timing belt cover right?
3. I have a cable jdm S1 transmisson and i wanted to know wut car do i buy a clutch and wut car do i buy an OBX LSD for? (already bought the lsd for a 90-93 ls integra/92-93 GSR/ 99-00 civic si just want to make sure i bought the right thing)
thanks
Old May 15, 2006 | 11:37 AM
mymeatb18
Default Re: couple ?s, feedback greatly appreciated (mymeatb18")
bump
Old May 15, 2006 | 11:39 AM
Orangecivic251's Avatar
i dunno about pulleys i was always told not to use the crank pulley not sure of teh others
Old May 15, 2006 | 12:12 PM
DonF's Avatar
Default Re: couple ?s, feedback greatly appreciated (OrangeCiviC251)
Why would you be using a obd0 oil pump, it is only 25 years old. Buy a new one.
Old May 15, 2006 | 12:33 PM
Runnerdown's Avatar
you need a 90-91 integra clutch. Buy a new oil pump. You have the right obx diff. I hope they redesigned that differential. I had to destroy an axle on my friends s1 because they didnt chamfer the splines inside so the ring could compress.
Old May 15, 2006 | 05:12 PM
mymeatb18
Default Re: (Runnerdown)
thanks for the replies guys but im already spending a lot of money building this engine (on a tight budget) and i already have an extra oil pump from my b16, already bought a new water pump and for the lsd wut if i just take off the ring on the axle to prevent this problem
thanks again
Old May 15, 2006 | 05:15 PM
drift4jesus's Avatar
Default Re: (mymeatb18")
The ring is supposed to hold the axle in place.
I had one pop out of the diff on me at the track once. Thought I blew the trans then didn't see any fluid.
Old May 16, 2006 | 07:38 AM
mymeatb18
Default Re: (drift4jesus)
well wutever i dont really need to take the axle out unless im changing the axles so ill just do with wut i got but i also need and answer on my oil pump please
thanks
Old May 16, 2006 | 04:16 PM
mymeatb18
bump
Old May 16, 2006 | 05:08 PM
dinko's Avatar
like DonF said...invest in a new oil pump. when your ragedy old *** oil pump takes a **** you're gonna come back on HT and cry to us bout how your motor got fucked
Old May 16, 2006 | 05:59 PM
mymeatb18
Default Re: (dinko)
ok ***** wutever when u find my nuts in your mouth in the morning then we'll see whos crying
brharris777
10
Jan 12, 2011 09:18 PM
061000rr
May 28, 2009 12:25 PM
pjr710
Jul 29, 2008 08:57 PM
90teg
Dec 19, 2004 04:21 PM
