Does you OBX LSD whir a little bit?
Old May 14, 2006 | 05:13 AM
bdavis's Avatar
Default Does you OBX LSD whir a little bit?
just put mine in last week and it tends to whir / whine at little bit on the street, not under power really, just cruising. it doesnt sound bad and there is no metal in my tranny.
thanks
burke
Old May 14, 2006 | 08:28 AM
efi2nr's Avatar
From: Home of the fastest Hondas in the 417 area since, 1997, usa
Default Re: Does you OBX LSD whir a little bit? (bdavis)
did you check the clearance on your beaings or did you just put it in
Old May 14, 2006 | 09:03 AM
bdavis's Avatar
Default Re: Does you OBX LSD whir a little bit? (efi2nr)
i shimmed it correctly
Old May 14, 2006 | 01:06 PM
HYBRID_H@TCH's Avatar
did you use another ring gear with your same counter shaft?
Old May 14, 2006 | 01:17 PM
TeamNextGenChris's Avatar
never had any problems like that.
sounds like maybe a damaged bearing.
Chris
Old May 14, 2006 | 04:23 PM
bdavis's Avatar
Default Re: Does you OBX LSD whir a little bit? (TeamNextGenChris)
hmmm, same ring gear and new bearings albiet they are not oem honda and i had to use 2 shims to get the proper clearance. im driving 200 miles to detroit tomorrow so wish me luck
Old May 14, 2006 | 04:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, same ring gear and new bearings albiet they are not oem honda and i had to use 2 shims to get the proper clearance. im driving 200 miles to detroit tomorrow so wish me luck </TD></TR></TABLE>
did you put the shims on the proper sidwe of the diff.if they're on the wrong side,ithink the ring gear may contact the case.
also,needle bearings or sealed ball bearings for the diff carriers?
Chris
Old May 14, 2006 | 05:05 PM
efi2nr's Avatar
I would say
1 the bearings could have been damaged when they were pressed on
2 I would use OEM bearings but thats just me
Old May 15, 2006 | 05:24 AM
bdavis's Avatar
hmm maybe the bearings, they were sealed and i took off the seals. oh well to detroit i go! interview with Roush!!
oh i think may have jacked up my speedo gear. i kinda just knocked it off
Old May 15, 2006 | 10:08 AM
SPOOLINmatt's Avatar
its nothing. I know they arent the same but they are similar, but my quaife has always whined and i asked quaife and they said it was normal and they have lifetime warranties soo.....i dont think you have any issues there.
Old May 16, 2006 | 12:18 PM
bdavis's Avatar
Default Re: Does you OBX LSD whir a little bit? (SPOOLINmatt)
i made it there and back! phew!! no problems, just still whining when under light load. oh well, im gonna run it till something blows
Old May 16, 2006 | 04:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdavis &raquo;</TD></TR><TR><TD CLASS="quote">whining when under light load. </TD></TR></TABLE>
sounds similar to symptoms i've had when the tranny fluid level is too low.
Chris
Old May 16, 2006 | 08:55 PM
exactly, light loads, its normal. just DRIVE!!
Old May 17, 2006 | 05:23 AM
bdavis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
i checked that, i squeezed almost two quarts in there
thanks for the help everyone, i really appreciate it. just wanted to make sure i didnt do something horribley wrong
mach3lude
Aug 29, 2011 07:18 AM
beyond-redline
May 22, 2007 06:04 AM
vha27
Dec 14, 2005 11:00 AM
dnatrance
Jan 24, 2005 02:10 PM
Boostage
May 10, 2004 05:25 PM
