92 civic cx intake manifold converted to Dx
My question is I swapped everything in correctly, but yet its still idles high. What is wrong here? Need help! Does the DX ecu needs to be put in or something else? Thanks for your help kinda needed to know asap. Car running like shiet!
on the upper left had side of the throttle body there is a adjustment screw its just a little circle with a slot in it stick a flat head screw driver in ther and adjust as needed
Do you have a vacuum leak mehbe? Is it bouncy?
Also, it might have something to do with the FITV that the CX doesn't have, but I'm pulling that out of my ***.
EDIT: You reused your CX injectors, right?
Its not bouncy though. My car just stays at 2000 rpm and when trying to drive the car it won't go past 2500 rpm. Meaning once I reach that point the car won't go no more. Still trying to figure out hte problem.
1meangsr
Feb 17, 2004 06:20 PM
hawjboi
Jun 20, 2002 07:17 AM
