92 civic cx intake manifold converted to Dx
Old 05-14-2006, 12:37 AM
aznfoboi25's Avatar
Default 92 civic cx intake manifold converted to Dx
My question is I swapped everything in correctly, but yet its still idles high. What is wrong here? Need help! Does the DX ecu needs to be put in or something else? Thanks for your help kinda needed to know asap. Car running like shiet!
Old 05-14-2006, 07:45 AM
ATX45's Avatar
Default Re: 92 civic cx intake manifold converted to Dx (aznfoboi25)
on the upper left had side of the throttle body there is a adjustment screw its just a little circle with a slot in it stick a flat head screw driver in ther and adjust as needed
Old 05-14-2006, 08:29 AM
SVOboy's Avatar
Do you have a vacuum leak mehbe? Is it bouncy?
Also, it might have something to do with the FITV that the CX doesn't have, but I'm pulling that out of my ***.
EDIT: You reused your CX injectors, right?
Old 05-14-2006, 09:18 AM
boosted civic 2k6's Avatar
dudes right. adjust your idle unless it shoots over 2000rpm when cold and 500rpm when warm.
Old 05-14-2006, 10:41 AM
aznfoboi25's Avatar
Default Re: (SVOboy)
Its not bouncy though. My car just stays at 2000 rpm and when trying to drive the car it won't go past 2500 rpm. Meaning once I reach that point the car won't go no more. Still trying to figure out hte problem.
Old 05-14-2006, 11:27 AM
schardbody's Avatar
haha, listen to svoboy, which injectors did you use, the cx or the dx??????
Old 05-14-2006, 11:45 AM
aznfoboi25's Avatar
I used the CX because my DX didnt have it.
fred92htch
08-23-2004 09:31 AM
1meangsr
02-17-2004 06:20 PM
hawjboi
06-20-2002 07:17 AM
CivilizedCiv
05-01-2002 08:56 AM
hybrid_KJ
08-09-2001 07:54 AM
Quick Reply: 92 civic cx intake manifold converted to Dx
