Turbo goes on tonight!
Old Apr 11, 2002 | 07:57 AM
TurboSedan's Avatar
New User
Default Turbo goes on tonight!
The turbo install starts tonight! The oil pan is coming off to be welded tomorrow morning. I plan to have everything mounted/installed except the oil lines tonight. Tomorrow when I get the pan back, the oil lines will get finished and the car will be up and running! Wish me luck!
P.S. This is a T3 60 on a D16Y8, intercooled and set to run 6.5Psi.
Old Apr 11, 2002 | 08:00 AM
gsr squirrel's Avatar
New User
Default Re: Turbo goes on tonight! (97CivicFerio)
good luck!
Old Apr 11, 2002 | 09:09 AM
TurboSedan's Avatar
New User
Default Re: Turbo goes on tonight! (gsr squirrel)
Thanks, I will let ya know how it goes!
Old Apr 11, 2002 | 08:13 PM
TurboSedan's Avatar
New User
Well, I have the manifold/turbo/wastegate mounted up. I took the oil pan off and drilled the hole for the drain fitting to be welded tomorrow. Then I will run the IC piping and mount the IC to the bumper. I also plan tomorrow to have a pipe bent to attach my K&N to the compressor inlet, and have a custom closed-loop downpipe fabricated.
Old Apr 11, 2002 | 08:45 PM
HXMan's Avatar
So it begins! Awesome. I hope to be in the same boat as you in the next few weeks.
When are you going to payne tech to get your hondata programmed? I want to know how they do.
Old Apr 11, 2002 | 09:02 PM
TurboSedan's Avatar
New User
Default Re: Turbo goes on tonight! (HXMan)
I am not sure on that yet, HXMan. We'll see how things go, but everything I have heard has been positive about Payn-Technologies.
Old Apr 11, 2002 | 11:41 PM
SIK IN DA HED's Avatar
New User
way to go! good luck on the project...
Old Apr 14, 2002 | 05:46 PM
TurboSedan's Avatar
New User
Default Re: Turbo goes on tonight! (dlplayboy)
Update:
There has been a minor set-back because the local custom welder has been swamped lately. He is the only one around here that welds aluminum. The oil pan is going to be welded tomorrow. I have everything else done and ready to go. I will just have to be patient. That is easy now because I have been buying turbo parts for about 6 months! LOL
[Modified by 97CivicFerio, 9:46 PM 4/14/2002]
Old Apr 16, 2002 | 08:40 AM
TurboSedan's Avatar
New User
Ok, well I finally have the oil pan from the welder and it is perfectly welded. He tested it to make sure it is leak-proof even, what a guy! Anyway, the car will be running tonight and everything should be cool!
Old Apr 17, 2002 | 03:57 AM
TurboSedan's Avatar
New User
Well, the oil pan did not leak but I did have a small leak right at the brass "t" where the line from the block goes to it. I did not have time last night to correct it, but I will be working on that tonight. I am not too unhappy by it, hell I have waited this long.....what is one more day!?!?
Old Apr 17, 2002 | 01:21 PM
FBP Ex-T's Avatar
wow man congrats...finally..i wish i couldve ahd my setup in by now...i just took my car to the dealer..my first and second gear synchro's are fu--d up so im gonna see wat happens there ....but i hope that ur setup comes out good..keep us posted..
Old Apr 17, 2002 | 01:30 PM
FBP Si 2000's Avatar
Default Re: Turbo goes on tonight! (FBP Ex-T)
Good luck and have fun.
Old Apr 17, 2002 | 02:09 PM
SiRkid's Avatar
Default Re: Turbo goes on tonight! (FBP Si 2000)
no fair ....good luck man!
Old Apr 17, 2002 | 03:40 PM
GSRwBOOST's Avatar
Default Re: Turbo goes on tonight! (SiRkid)
ek98gsr
Feb 6, 2015 10:56 PM
justYncredible
Feb 8, 2012 10:20 AM
BEEYOND
Sep 2, 2004 01:08 PM
2000vsm
Aug 7, 2003 09:30 AM
echo999
Sep 26, 2001 08:18 PM
