VTEC NOT WORKING?
Old May 13, 2006 | 03:06 AM
midnitesol's Avatar
Default VTEC NOT WORKING?
vtec will work fine if i just accelerate normally but once i launch or slam it into 2nd it cuts out and bogs. please help!!
Old May 13, 2006 | 05:41 AM
Honda Dave's Avatar
Default Re: VTEC NOT WORKING? (midnitesol)
is this a swap or factory vtec motor??????
if swap check your connections to the ecu and to the motor . check the pins are correct.
check your OIL level in the thing might be like a quart low.
had this prob before and it was low on oil if that helps
Old May 13, 2006 | 05:48 AM
Mr JDM South's Avatar
Default Re: VTEC NOT WORKING? (oneflybiker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneflybiker &raquo;</TD></TR><TR><TD CLASS="quote">is this a swap or factory vtec motor??????
had this prob before and it was low on oil if that helps</TD></TR></TABLE>
agreed.
Old May 13, 2006 | 11:41 AM
midnitesol's Avatar
Default Re: VTEC NOT WORKING? (Mr JDM South)
its an 01 gsr with a ctr tranny in a 95 del sol. i swapped it about a week ago and it ran fine until the track. once i launched to warm up my tires it stopped working evrytime the car jerked or bounced. but it still works when i drive normally.
my oil is fine.
was stock b16 so connections r all fine.
could it be that we extended a sensor even though the connection looks fine?
Old May 13, 2006 | 11:52 AM
midnitesol's Avatar
bump
please help!
Old May 13, 2006 | 12:40 PM
midnitesol's Avatar
yeah figured it out!!!
plug under steering wheel was loose vtec feels good again!
Old May 13, 2006 | 12:41 PM
midnitesol's Avatar
thanx for all ur help!!
Old May 13, 2006 | 08:27 PM
Honda Dave's Avatar
oh yes i almost forgot about that one.......dayum i have been on my bike to long!!!!!!!
Old May 13, 2006 | 08:29 PM
spoonracer84eg's Avatar
Default Re: (oneflybiker)
Which plug exactly was it that was loose. Just curious.
Old May 14, 2006 | 11:09 PM
midnitesol's Avatar
Default Re: (spoonracer84eg)
not sure what its called i just know when its unplugged ur car wont start so it must hav not plugged it back in good enough! my sister started my car that day!
its on the driver side against the side and firewall almost. in most cars its a brown plug but im not sure if its so on all of them.
Old May 15, 2006 | 03:06 AM
fmrprojects's Avatar
Default Re: (midnitesol)
its the main relay
honda4life17
Jul 15, 2007 12:03 PM
h22silvia
Nov 25, 2006 11:10 AM
h22silvia
Nov 9, 2006 07:59 AM
FlatTire
31
Sep 4, 2004 03:00 PM
spoonef
Feb 28, 2003 10:01 AM
