Air From Dip Stick??
Old May 12, 2006 | 11:21 PM
Ransom's Avatar
Default Air From Dip Stick??
Alright, just put the gsr in my girlfriend's coupe and when i shut the car off, i can pull the dip stick up and a little bit of air comes out. Ive already changed out the PCV valve and that didnt help. So far the engine feels strong, idles good, and no smoke from the exhaust. Im thinking possibly rings? Im going to be pissed if it is and hmotors will get from me. Oh i will be doing a compression test tomorrow also.
Old May 13, 2006 | 12:38 PM
SiYouLater's Avatar
Default Re: Air From Dip Stick?? (LudeSH)
Do a leakdown test. That should determine the problem.
Old May 13, 2006 | 10:06 PM
Ransom's Avatar
Default Re: Air From Dip Stick?? (99FBPSi)
Something has to be clogged, causing it not to vent... i dont have a leakdown tester.
Old May 14, 2006 | 02:10 PM
Ransom's Avatar
up, im scared to drive this thing like this.
Old May 14, 2006 | 10:55 PM
Ransom's Avatar
Old May 15, 2006 | 12:54 PM
Pikachu's Avatar
That's blowby. When my H22 rings went, it started doing that and then it started smoking. If it doesn't smoke, then I'm not sure. Maybe a valve adjustment?
Old May 17, 2006 | 12:45 AM
Ransom's Avatar
Default Re: (Pikachu)
I got it to stop by pulling the pcv valve out of the black box and letting it vent into the atmosphere. im guessing something is clogged in the hose or manifold.
Old May 17, 2006 | 04:04 PM
postman's Avatar
Default Re: (LudeSH)
squeeze along your pcv tubing and listen for idle drops to find the clog
hondamatt89
Mar 17, 2015 11:19 AM
builtITRm22x
10
Sep 22, 2008 08:09 PM
turbo95eg6
Jul 10, 2005 07:22 AM
Alpha_GSR
May 16, 2002 09:23 AM
Stunna BEN
Nov 18, 2001 11:01 AM
