38mm wastegate good for 600whp
Old May 12, 2006 | 07:06 PM
Quickgti1.8t's Avatar
Default 38mm wastegate good for 600whp
Since my car is down for a rebuild. I was wondering if i should change my tial 38mm with 1 bar. Should i go 44mm or stay with 38mm. I ran 22psi minimum before on my stock engine. So my pump gas will be 22psi and race gas 40psi.. Im wondering if the 38mm will hurt or not
Old May 12, 2006 | 07:11 PM
HamiltonRex's Avatar
Default Re: 38mm wastegate good for 600whp (Quickgti1.8t)
Low boost.. Big turbo = Big wastegate
High Boost.. Big Turbo = Small wastegate
Reason for... If you run low boost with a big turbo, wastegate works harder.. So it needs to be bigger to prevent creep.
Going to a 44mm wouldnt hurt.
Old May 12, 2006 | 07:27 PM
Default Re: 38mm wastegate good for 600whp (HamiltonRex)
i have a gt35r already and basically plan on running 25psi+
Old May 12, 2006 | 07:55 PM
CRVRX's Avatar
A well placed 38mm Tial will hold a GT35R down to 7 psi no problem. An Inline Pro manifold for instance.
Old May 12, 2006 | 08:57 PM
Default Re: 38mm wastegate good for 600whp (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX &raquo;</TD></TR><TR><TD CLASS="quote">A well placed 38mm Tial will hold a GT35R down to 7 psi no problem. An Inline Pro manifold for instance.</TD></TR></TABLE>
i wont handle running 7psi. My minimum will be 20psi daily
Old May 12, 2006 | 10:43 PM
Fitti's Avatar
go with the 44mm a GT35R will not flow that much boost it will die out well before 40psi.
Instead of worrying about how much boost you are going to running. You should look at it if you can make 400 on 10lbs of boost or 400 on 21lbs of boost which would be safer and allow the engine to last longer
Old May 13, 2006 | 10:28 AM
Default Re: 38mm wastegate good for 600whp (Fitti (Godzilla))
well its a VW 1.8T its pretty different then a honda. I basically need twice the PSI you guys run to get the same power
alex37211
Apr 8, 2009 03:50 PM
Markb16a
Oct 16, 2007 08:45 PM
A2gt35r
Mar 19, 2007 07:34 PM
16vt
May 29, 2005 10:55 AM
V-SPEC 1
Apr 29, 2004 07:43 AM
