Weird Brake problem
My first post in motorcycle forum.
well i just got my first bike, it was a steal!
2001 cbr f4i, 10000 miles mint condition, clean title
but it has a front brake problem. the owner was very open with me about it so i took it with out delay
the brake problem is as follows, sometimes the front brake doesnt grab, like you have to pull it twice, he thinks its a warped rotor pushing the pads out.
it only happens like once out of every 10 times you pull the brakes, but i just want to get it solved before i ride it hard
im not sure whats wrong with the brake,
but if it was my bike, i would just replace everything for piece of mind.
it could also be an excuse to upgrade to some sweet brakes
SS lines, rotors, pads, calipers. the works.
good luck with fixing the problem if your on a budget.
.SS lines, rotors, pads, calipers. the works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">My first post in motorcycle forum.
it only happens like once out of every 10 times you pull the brakes, but i just want to get it solved before i ride it hard</TD></TR></TABLE>
make sure all connections are tight, bleed the brakes/change fluid, check pads, check master cyl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngng »</TD></TR><TR><TD CLASS="quote">
make sure all connections are tight, bleed the brakes/change fluid, check pads, check master cyl</TD></TR></TABLE>
i wouldnt ride untill problem is fixed. and ride in small street or back road for test. besafe
"I" before "E" except after "C"
But it does sound like bad rotors.
After i wrecked my f4i i had the same problem. I could pull the front brakes in and nothing would happen. My rotors were so bent that it hardly grabed if at all. So i replaced them and problem was fixed!
He is right about the rotors pushing the pads out as well.
AzntaggeR
Honda Motorcycles
11
Apr 25, 2017 11:12 PM
