Weird Brake problem
Old May 12, 2006 | 06:49 PM
built562's Avatar
Default Weird Brake problem
My first post in motorcycle forum.
well i just got my first bike, it was a steal!
2001 cbr f4i, 10000 miles mint condition, clean title
but it has a front brake problem. the owner was very open with me about it so i took it with out delay
the brake problem is as follows, sometimes the front brake doesnt grab, like you have to pull it twice, he thinks its a warped rotor pushing the pads out.
it only happens like once out of every 10 times you pull the brakes, but i just want to get it solved before i ride it hard
Old May 12, 2006 | 10:31 PM
knockout's Avatar
Default Re: Weird Brake problem (built562)
im not sure whats wrong with the brake,
but if it was my bike, i would just replace everything for piece of mind.
it could also be an excuse to upgrade to some sweet brakes .
SS lines, rotors, pads, calipers. the works.
good luck with fixing the problem if your on a budget.
Old May 12, 2006 | 11:35 PM
ngng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">My first post in motorcycle forum.
it only happens like once out of every 10 times you pull the brakes, but i just want to get it solved before i ride it hard</TD></TR></TABLE>
make sure all connections are tight, bleed the brakes/change fluid, check pads, check master cyl
Old May 13, 2006 | 12:49 AM
__oversea's Avatar
Default Re: Weird Brake problem (ngng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngng &raquo;</TD></TR><TR><TD CLASS="quote">
make sure all connections are tight, bleed the brakes/change fluid, check pads, check master cyl</TD></TR></TABLE>
i wouldnt ride untill problem is fixed. and ride in small street or back road for test. besafe
Old May 13, 2006 | 05:53 AM
mike5809's Avatar
"I" before "E" except after "C"
But it does sound like bad rotors.
After i wrecked my f4i i had the same problem. I could pull the front brakes in and nothing would happen. My rotors were so bent that it hardly grabed if at all. So i replaced them and problem was fixed!
He is right about the rotors pushing the pads out as well.
Old May 13, 2006 | 07:49 AM
crxgator's Avatar
Default Re: Weird Brake problem (mike5809)
actually, he spelt "weird" correctly...
AzntaggeR
Honda Motorcycles
11
Apr 25, 2017 11:12 PM
DaCRXboi
Mar 14, 2006 09:59 PM
josephshark
12
Dec 19, 2005 01:34 PM
dnote
Aug 3, 2004 10:09 AM
92 GS-R
Nov 25, 2002 03:27 PM
